Anyone do this? #1005598 08/09/10 09:08 PM
Cholltero Offline OP
Just got started replacing front CV boots and upper and lower ball joints on the 95' 4runner.
FSM says remove wheel and hub etc., remove differential flange nuts and drop the whole short shaft out.
Yeah, right.
Well, to get the Short shaft out , I ended up removing the nut on top of the shock, unhooked the stablelizer bar, and the upper ball joint in order to get enough room to pull the short shaft.
If the front diff flange studs were removable bolts instead I think I could have just dropped it out of there.
My question is has any one replaced their studs with bolts??
Thanks
85' 4x4 e-cab flatbed 22r carb ((SOLD))
86' 4runner, 22re , "60 buck truck"
95' 4runner, 22re,5sd, last of the good ones
02' Tacoma prerunner, 2.7L, 5spd., 4x4
Re: Anyone do this? [Re: Cholltero] #1005599 08/10/10 01:12 AM
kewlynx Offline
What's been done in the past is that folks have pressed the bolts out, shaved the splines down to where the bolt still fits tightly, and used a nut/lockwasher.
Cheap trick that's been around awhile, started with the 80's IFS.
**ubi apis- ibi salus**
Re: Anyone do this? [Re: kewlynx] #1005600 08/10/10 02:09 AM
ChrisH Offline
i did exactly this. it worked like a charm!
i would recommend some red loctite threadlocker. i did that and lock washers. it was a cheap fix. all it took was a bench-grinder to grind the splines off. you don't need to take off much.
this allowed me to change my CV's in the woods, if i had to.
just a couple of wrenches and a socket set smile
oh also instead of pressing them out, i put the nuts on the end to protect the threads and beat on the nuts.
don't mangle them up too much though!
'95 Toyota Pickup DX Xtended Cab ~ Daily Driver
Re: Anyone do this? [Re: ChrisH] #1005601 08/10/10 05:24 AM
RatLabGuy Offline
I've done this too.
in fact, isn't there a write upon this here somewhere?
It not only makes dealing with the CVs easier, but removing/installing the front diff as well.
One note, if you have BJ spacers, you cannot do the trick of pulling the CVs w/o removing the upper balljoint. The angle is too steep, by like 1".
Question Reality.
Re: Anyone do this? [Re: RatLabGuy] #1005602 08/10/10 09:49 AM
Snowtoy Offline
Might depend on how much you have the torsion bars cranked. I have the spacers on my '91 and was able to pull the CV w/the wheel still on.
Re: Anyone do this? [Re: Snowtoy] #1005603 08/10/10 04:08 PM
Thanks for the replies guys, gotta love this board.
After a couple of whacks with a five pound sledge and big drift on the nut on the stud bolt I thought that shock might be not too good for the front diff.
So I bought one of these .
http://www.harborfreight.com/air-impact-hammer-kit-32940.html
Best 7 bucks I ever spent . Used the pointy tip attachment in the reccess of the end of the stud and pulled the trigger and bamm! out of there. Couldn't freakin believe it.
And I also purchased a pickle fork attachment for the air hammer which made removing the ball joints much easier too.
So , I'm going to grind the studs till they're just snug and loctite/lockwasher them back in.
Other than feeling guilty for supporting the Chinese economy, it was a good day
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6107 MB (Peak: 0.6969 MB) Data Comp: Off Server Time: 2026-07-15 02:32:30 UTC
