Compatibility Questions #1005638 08/10/10 04:04 AM
N
NickR Offline OP
1)Came across a 1991 Gen 2 SR 3.0L with 4.875 gears. In order to use them on a Gen 1 2.6L I need a Gen 1 SWB 3.0L front end?
2)The Gen 2 front carrier assembly will fit into the Gen 1 SWB 3.0L front housing, No need to set the gears?
3)Will a Gen 2 SR 3.0L rear carrier assembly bolt up to a Gen 2 3.5L carrier? no need to set the gears?
1987 Dodge Raider, stick on 33", 2.5" BL, Con-ferr roof rack, Hella driving lights & pencil beam lights.
Stuff collecting dust in the garage
SR Axle
LSD 3rd member
Early Gen 1 Bouncy seat
Early Gen 1 two piece rear bumper
2 sets of SWB Gen I rear seat-belts.
Set of Aisin Hubs.
Re: Compatibility Questions [Re: NickR] #1005639 08/10/10 05:43 AM
motero Offline
Yes,but it does not have to be from a SWB.
Yes it will fit, you will have to set up the gears.
No, different sizes.
Good luck, but wait for some one to verify my memory.
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
Re: Compatibility Questions [Re: NickR] #1005640 08/10/10 06:09 AM
0778drz110 Offline
I thought an early 90s Gen2 4.88s were High pinion 7.25", gen 1s are all low pinion
Re: Compatibility Questions [Re: motero] #1005641 08/10/10 06:11 AM
justice Offline
I dont think you can swap the front end gears over to the gen 1 housing. The Gen 2's front end gears are a high pinion design and are cut different.
Re: Compatibility Questions [Re: justice] #1005642 08/10/10 06:40 AM
Can the gen ii front carrier assy be swapped as a whole?
Re: Compatibility Questions [Re: off-roader] #1005643 08/10/10 03:26 PM
justice Offline
No, the mounting setup is different.
Re: Compatibility Questions [Re: justice] #1005644 08/10/10 03:33 PM
monte Offline
Justice,
in your thread about the trip, you mentioned John's specs on his ride..
John had his 90 LWB with 33's,Crawler Gears, 5.29's and ARB airlockers in both diffs Gen 2 Trailing arms, RB sliders and tube bumper.
Where did the 5.29's come from? Where those the Aus cut ones or from Mr.bishi?
I'm needing something bad now to up this ratio. This auto trans is not cutting it.
Thanks buddy!
Jason
1986 SWB Turbo Pajero (aka RedCar). 2" Lift, 33" BFG ATs, Rear locker,Custom 160a Alt, 9000lbs Warn Winch,Con-Ferr Custom built Conferr rack just for RedCar!, Safari Snorkel,3 AGM Deep cycles
1995 SR (Lucky)-SOLD..Kinda sad
Nissan Leaf(Astro), Tesla-S 85kw (Nicoli) & 2014 Rav4EV (Tesla inside)
Re: Compatibility Questions [Re: monte] #1005645 08/10/10 09:45 PM
justice Offline
Justice,
Thanks buddy!
Jason
Not sure, you'll have to ask john, Lloyd or, Capt Crunch. All those guys run the 5.29's.
The source might of dried up by now, in which case you can still go to 4.88.
Re: Compatibility Questions [Re: 0778drz110] #1005646 08/11/10 02:12 AM
N
NickR Offline OP
Thanks for the reply's
I though Gen 2 came in high pinion & low pinion, also i thought v6 Montero's front ends were 8" and the 2.6l were 7.25" <img src="/forums/images/graemlins/confused.gif" alt="" />.
SR Axle
LSD 3rd member
Set of Aisin Hubs.
Re: Compatibility Questions [Re: NickR] #1005647 08/11/10 02:33 AM
0778drz110 Offline
i thought the gen2 3.0L automatic models came with a small 7.25" HP front, early gen2s had 4.875 gears
http://www.outerlimits4x4.com/viewtopic.php?f=4&t=23638
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6442 MB (Peak: 0.7709 MB) Data Comp: Off Server Time: 2026-07-17 07:50:16 UTC
