Time for new tires #1005662 08/11/10 12:05 AM
jasonjj Offline OP
Hey guys, sorry for the novice post, and i realize this has probably been covered here a lot already. I just dont have the time this evening to do the research. I have a 95 LS monty with stock wheels. I was going to get new tires and currently have 31 10.5 15R. WHats the biggest size i can put on my stock wheels without any modification? Thanks
Re: Time for new tires [Re: jasonjj] #1005663 08/11/10 01:04 AM
motero Offline
33x10.50x15 or 33x12.50x15 with a little rubbing in the front.
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
Re: Time for new tires [Re: motero] #1005664 08/11/10 02:47 AM
jasonjj Offline OP
Do both sizes rub or just the 33x12.5? I was thinking about getting the 33x10.5 if they fit ok. Thanks
Re: Time for new tires [Re: jasonjj] #1005665 08/11/10 02:04 PM
hazy_daze Offline
33x10.50's will fit fine.
Re: Time for new tires [Re: hazy_daze] #1005666 08/11/10 07:26 PM
jasonjj Offline OP
Cool, i think thats what im going to go with. Do you find that many places will not put on that size?
Re: Time for new tires [Re: jasonjj] #1005667 08/11/10 08:27 PM
jasonjj Offline OP
So, i was thinking about getting the 33x10.5x15 on my stock wheels. I mentioned this to my bro, who doesnt have a monty but who knows trucks and tires pretty well, and he acted as if thats a big a$$ tire. WOuld that really look all that huge on my truck? Anybody have a picture of what 33s look like on a stock rig? I had 31s on there which look fine, just thought i wanted a slightly bigger look. Any info would be appreciated.
Re: Time for new tires [Re: jasonjj] #1005668 08/11/10 08:51 PM
RECON45 Offline
If you are looking at the 10.50 width tires then they should not look much different than what you are running. it is only going to be 1" all around the tire. So if you are worried take your hand on top of your current tire around it to see how much room you will have between the top of your hand and your fender. This should help answer everything. Do not forget to turn your tires and see how much room you have with the tires at angle to your fender, but like what everyone on here is saying you should be fine.
Here is 33x12.50 with no lift. Old picture the only one I have.
Re: Time for new tires [Re: jasonjj] #1005669 08/12/10 07:51 AM
Dylan Offline
Below are some photos of mine when my 33x12.5's were like 1 day old. Of course mine is an SR, so it sits just a touch higher, but as others stated, you should be fine. Even though mine are 12.5 wide, I still don't have any rubbing up front and I do not have any lift except for about a 1.25" t-bar crank. Or rather I wouldn't if I would get under it and replace the steer stop I have right now that is missing it's end cap. I don't bother though because the only rub is on extreme left hand turns and then is only light rubbing on the sway bar...
Anyway, here's the photos....
Hope that helps you a bit!
'95 Montero SR 3.5L, Trail Gear Sliders, Rugged Ridge XHD Front Bumper, 33x12.5 Duratracs, much more in the works....
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6247 MB (Peak: 0.7231 MB) Data Comp: Off Server Time: 2026-06-07 07:24:35 UTC
