Page 7 of 9 1 2 3 4 5 6 7 8 9
Re: Anyone interested in Sway-away torsion bars? [Re: FrankR] #1005771 09/24/10 01:07 AM
hazy_daze Offline
That sounds backwards.
Re: Anyone interested in Sway-away torsion bars? [Re: hazy_daze] #1005772 09/24/10 10:11 AM
E
evotechnik Offline
im in for a set of Gen 1's
Re: Anyone interested in Sway-away torsion bars? [Re: hazy_daze] #1005773 09/24/10 11:42 AM
FrankR Offline
Inline engines are often heavier than similar displacement V engines. I wouldn't think there would be a lot of difference between the weight of the 2.6L and 3.0L, but the engine weight may be carried a little further foward in the 2.6L. However, the specs show the curb weight of the 2.6L to be lighter overall than the 3.0L.
The FSM agrees with Dave in that the bar diameter is more for the 2.6L, but it gives the spring specs in different measurements:
2.6L = Spring constant (wheel position when body set) - 123 lbs/in
3.0L = Torsion spring constant - 25.03 ft.lbs/degree
Frank
Re: Anyone interested in Sway-away torsion bars? [Re: FrankR] #1005774 09/24/10 07:15 PM
hazy_daze Offline
So, how would one convert those different measurements to something that could be compared side-by-side?
Re: Anyone interested in Sway-away torsion bars? [Re: hazy_daze] #1005775 09/24/10 07:54 PM
FrankR Offline
Damfino - maybe Kevin has an engineering book that can provide some insight in the relationship of those 2 disparate measurements.
Frank
Re: Anyone interested in Sway-away torsion bars? [Re: FrankR] #1005776 09/24/10 10:36 PM
A
airbats801 Offline
So what did the hd 2.6l come in? Was it part of the fofrad package?
8 Starion SHP, 87 mitsubishi van, , 81 galant g54bt, 78 lancer g54bt, 1965 Mitsubishi Debonair Deluxe
87 swb montero offroad pkg goin g54bt with sr locker 33x12.5 dual bouncy.
Re: Anyone interested in Sway-away torsion bars? [Re: airbats801] #1005777 09/25/10 12:16 AM
hazy_daze Offline
I'm not familiar with the fofrad package. Was that something ya'll PNW fellers only got? <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Anyone interested in Sway-away torsion bars? [Re: hazy_daze] #1005778 09/25/10 03:49 AM
A
airbats801 Offline
I believe its jsut hadlight squirters bounc seat, and center gauges? Just realized that lol. Very special package for only the drunk people in the northwest.
Re: Anyone interested in Sway-away torsion bars? [Re: RaideroftheLostArk] #1005779 09/25/10 06:36 PM
KrzyDav Offline
I just looked on datapro and they list the same part number for the 2.6 and the 3.0 LWB. You can't trust part numbers you get on AllDataPro.
I'm guessing the 3.0 # I listed above is for my SWB 3.0.
The part numbers on my sheets list the anchor at adjuster and anchor at lower A -arm as the same part number for V6 and 4 cly, so yes the 2.6 bars should work for the 3.0.
Now if we could just find a deal on some SWB T-bars.
dave h.
Re: Anyone interested in Sway-away torsion bars? [Re: KrzyDav] #1005780 10/08/10 06:22 AM
montypower Offline
Any updates? Are they still available?
1995 Montero SR - 2" Body Lift, 35" BFG KM2, 2.5" Suspension Lift, Manual Hubs Searching
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6446 MB (Peak: 0.7685 MB) Data Comp: Off Server Time: 2026-06-07 08:36:57 UTC
