Fuel Pressure #1006291 08/16/10 12:46 AM
leadheavy52 Offline OP
So, while my starion engine is undergoing its rebuild,I've decided to work out the demons haunting my truck until the new motor is ready to go in. I have a Weber 32/36 DFEV and I do not run a fuel pressure regulator. Now my problem is this: The truck runs and drives fine, but lacks power. When I turn it off and it sits for a few minutes, it is really hard to start, almost like it is flooded. My theory is that without the fuel pressure regulator, the pump is pushing too much gas into the carb and when I turn it off, the overpressureized fuel lines are causing the carb to flood. I also notice the smell of gas and my carb to manifold gaskets are wet with gas. Would a fuel pressure regulator solve this problem or do I need to rebuild my carb?
-Austin
1988 SWB Montero - 2.6L - 5-speed
Weber Carb
(Coming Soon) Rugged Ridge AVM Hubs
Re: Fuel Pressure [Re: leadheavy52] #1006292 08/17/10 04:41 AM
You are probably overwhelming the needle valve in the bowl. I'd use an FPR for sure, with a return line. I think the weber likes a quite low fuel pressure. I seem to remember my old dcoe's and idf's only liking around 3-4psi...
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.5854 MB (Peak: 0.6340 MB) Data Comp: Off Server Time: 2026-07-17 01:11:59 UTC
