Left turn indicator and bulb stuck on intermetainly #1006322 08/17/10 02:13 AM
PCMONT Offline OP
Flasher seems to be working fine ? But when i push down on the stalk for left turn...... the indicator light (dash)and bulb stay on constant. Then a few minutes later...sometimes it flashes as should. Did a search in the archives but didnt find anything specific. Gonna rip into the stalk but wanted to see if anyone encountered this and had a fix.
thanks
91 LWB 3.0 w/300K. Nothing fancy yet...still getting the quirks out and cosmetic fixes.
Re: Left turn indicator and bulb stuck on intermetainly [Re: PCMONT] #1006323 08/17/10 02:22 AM
bamashooter Offline
Sounds like the contacts in the stalk need cleaning.
Re: Left turn indicator and bulb stuck on intermetainly [Re: bamashooter] #1006324 08/17/10 02:42 AM
4xmonty Offline
Of course make sure the bulbs are good.Then double check
the Flasher switch as this can affect the turn signals
Russ
GETTIN OLD THATS EARNED
Happy trails to you
(1)98 Montero SR RB Rock Crawlers BFG 33s Rancho 9000's OME Med coils rear
(2)95 4Runner All Pro Nerf bars BFG 32s
ARB bull bar
Downey 2" rear coils Downey headers
(3) 90 Montero LWB 3.0 auto
(4) 98 Kawi GPZ1100
Re: Left turn indicator and bulb stuck on intermetainly [Re: 4xmonty] #1006325 08/17/10 03:57 PM
8
89IsMine Offline
Sounds like the flasher switch to me -- this was how mine was operating when I first bought it. I replaced it with a generic flasher switch (just make sure the terminal pattern is the same) and it has worked great ever since.
Eric W.
Edited to add: I should clarify that when I said flasher switch I was referring to what seems to be called the turn signal flasher. Looks something like this:
Re: Left turn indicator and bulb stuck on intermetainly [Re: 89IsMine] #1006326 08/17/10 11:46 PM
PCMONT Offline OP
Thanks guys !
Will replace the flasher switch and then clean the stalk if needed.
Re: Left turn indicator and bulb stuck on intermetainly [Re: PCMONT] #1006327 08/18/10 12:11 AM
PHIL_ Offline
Sometimes you can narrow it down by jiggling the flasher switch a bit - mine usu acted up right after I had the flashers on, for some reason... I did take one apart and clean it out... this was 12 years ago, but I think I remember something about a little ball bearing that rides on the contact patch rolling along the garage floor? Better idea is to find a few at the junkyard and swap em in till you find a good working one. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Thankfully the genII went to a different switch, and the problem was eliminated, at least for some of us.
Re: Left turn indicator and bulb stuck on intermetainly [Re: PHIL_] #1006328 08/18/10 11:54 PM
PCMONT Offline OP
Went to remove steering wheel to clean out the stalk switch. Got the main nut and lock washer off but the darn bugger wont pull off. I PB blasted it and pulled on the top of the wheel while gently hitting the bottom with a rubber mallet. Nothing ! There are 2 tapped holes next to the nut i just took off. Are those required to make some kind pry plate that will pry the wheel off if i install screws and make a plate ? Hope that made sense ? The FSM didnt go into detail on steering wheel removal. Thanks !! Funny thing though....after tappping on the wheel...so far the indicator is working as should. But i would prefer to clean the switch.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6190 MB (Peak: 0.6939 MB) Data Comp: Off Server Time: 2026-05-29 22:44:27 UTC
