V8, V6 swap? or cams?? #1006332 08/17/10 02:08 PM
G
guzzilapd Offline OP
well its getting interesting on how to bring my Montero back to life. New heads for 170.00 eash plus shipping only come with valves. If I need new cams are there any performance cams I could put in?
Or how about an engine swap... or some good used heads already built up??
s
Re: V8, V6 swap? or cams?? [Re: guzzilapd] #1006333 08/17/10 03:51 PM
StockRaider Offline
I forget the company, but I do know its Aussie based. Performance cams, headers, ECU mod and I am sure you can find more if you look hard enough. I am sure others will chime in with the actual source. \
Personally I wouldn't go with another make swap, makes for better bragging rights when you know your still driving pretty much a stock setup. <img src="/forums/images/graemlins/lol.gif" alt="" /> If I did swap, I would be buying a 2.8 or 3.2 TD from the overseas models.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: V8, V6 swap? or cams?? [Re: StockRaider] #1006334 08/17/10 09:12 PM
rpw in aus.
Re: V8, V6 swap? or cams?? [Re: fasteddy] #1006335 08/19/10 03:25 PM
G
After looking at the prices on RPW I think Ill just rebuild the stock motor myself and leave it stock!
Re: V8, V6 swap? or cams?? [Re: guzzilapd] #1006336 08/19/10 03:32 PM
StockRaider Offline
Mods aren't going to be competitive with OE prices for a reason. <img src="/forums/images/graemlins/lol.gif" alt="" />
Richard E
1983 Honda XL600R
Re: V8, V6 swap? or cams?? [Re: StockRaider] #1006337 08/19/10 05:33 PM
Those are aussie dollars, not USD...
Re: V8, V6 swap? or cams?? [Re: fasteddy] #1006338 08/20/10 06:12 PM
G
1.125-1.0 exchange rate is not that much difference. if it were quid to greenback that would be a different story and better price for sure.
s
Re: V8, V6 swap? or cams?? [Re: fasteddy] #1006339 08/21/10 07:21 PM
G
Isnt there someplace in the God Ole Us of A makes and sells performance cams for Mitsu's??
Looked on JEGs site but could not really find anyting. cant believe AUS Company is the only Gig in town .
s
Re: V8, V6 swap? or cams?? [Re: guzzilapd] #1006340 08/21/10 08:02 PM
FrankR Offline
There's nothing available. You can swap in SOHC Diamante cams and gain top end performance, but probably lose some on the bottom end of the curve. If you can fashion a way to adjust the cam timing, you can find a decent compromise, but the only way to do that is:
1) Offset bushings for the sprockets, which requires drilling the sprockets, removing the locating pin from the cam nose, over-drilling the cam to receive a .25" locating dowel and a whole bunch of fiddling to get the cams timed.
2) A set of adjustable cam sprockets like these:
One of these days, I'll install them and find out which cams are best for the 3.0L SOHC engine and where they should be timed. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Frank
Re: V8, V6 swap? or cams?? [Re: FrankR] #1006341 08/22/10 08:19 AM
G
Now that is a Royal Pain in the A!
Im gonna keep it stock....Im rebuilding it for a 10 yr old wants to drive it when he gets his license!
s
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.006s) Memory: 0.6416 MB (Peak: 0.7644 MB) Data Comp: Off Server Time: 2026-10-22 07:40:05 UTC
