battery dash light turn on #1006601 08/20/10 04:51 AM
RadiOwATt1oo Offline OP
My battery dash light turn on but the trucks seems to be alright, should i take that like a warning from an alternator failure. Any advice
96 t100 automatic 4wd <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: battery dash light turn on [Re: RadiOwATt1oo] #1006602 08/20/10 05:00 AM
kewlynx Offline
Visual inspection is always first and foremost.
http://www.4x4wire.com/toyota/maintenance/alternator_brushes/
**ubi apis- ibi salus**
Re: battery dash light turn on [Re: RadiOwATt1oo] #1006603 08/20/10 01:16 PM
SCT100 Offline
The battery light usually indicates a bad charging system. My guess is that you are correct, and that your alternator is going bad (or is bad already). You can have Autozone or similar shops check it for free usually.
'97 Extra Cab 3.4 4x4 5sp 90K mi and counting.
Mods: KYB GAJs, Monroe damper, Marlin shifter seats, Kenwood sound, bedliner, Leonard shell, ES sway bar upgrades, Aisin Hubs...Best truck ever
Currently listening to: Ryan Adams and the Cardinals III/IV
Currently fishing for: reds and trout
Re: battery dash light turn on [Re: SCT100] #1006604 08/20/10 04:18 PM
I'll check it and let you know. thanks <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: battery dash light turn on [Re: RadiOwATt1oo] #1006605 08/24/10 06:46 PM
And bingo it was the alternator. There,it's fixed it.
Re: battery dash light turn on [Re: RadiOwATt1oo] #1006606 08/24/10 07:47 PM
SCT100 Offline
Awesome! <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: battery dash light turn on [Re: RadiOwATt1oo] #1006607 08/25/10 04:28 PM
BamZipPow Offline
My charging system isn't charging the battery. All voltage indicators (Scangauge II, cig socket reader) are reading 12V which tells me the battery isn't gitting the voltage. Cables and connectors are good and clean. Battery is topped up. I figured my charging light would indicate that there's a problem...but no it's failing at it's job. The bulb is good as I can see the indicator before I start the engine.
Just pulled the alternator off and checked the brushes. All worn down. <img src="/forums/images/graemlins/frown.gif" alt="" />
Gonna see if the local Toyota dealerships have the parts. Lucky me that there's an alternator place near me...A-Alternator & Starter Rebuilders, 900 Grand Ave, Bacliff, TX 77518, 281-339-9099!! <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: battery dash light turn on [Re: BamZipPow] #1006608 08/25/10 10:28 PM
BamZipPow Offline
No go on both places. Had the alternator tested at AutoZone. It failed. <img src="/forums/images/graemlins/frown.gif" alt="" />
Got another one from the local parts yard fer $50. At least I have something working fer now. I still find it strange that it didn't register the lack of charging. I wonder if the internal voltage regulator gave up the ghost and in that process it can't report back to the system that it's not charging? <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: battery dash light turn on [Re: BamZipPow] #1006609 08/26/10 02:20 AM
kewlynx Offline
I would imagine if all the diodes fried in the IC that would be the case.
If you go to the tech articles at autoshop101 for charging systems, about page 6, there's a good schematic of the IC for the alternator. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6271 MB (Peak: 0.7305 MB) Data Comp: Off Server Time: 2026-06-07 07:22:15 UTC
