2.6l engine mounts #1006825 08/24/10 02:35 AM
sandhill_raider Offline OP
Got my 2.6 bolted to the tranny, but now the new aftermarket engine mounts are not fitting correctly. I bought them from Advance, first mistake, and have checked the part number (2731) with my normal parts house guy. He shows the same number. The number on the side of the new mount is MB006605, number on the old MB260572. Has anyone already solved this riddle?
1988 Dodge Raider, Clearwater, 33x12.5 Buckshots, RB 2" Lift, Weber, 2.6L rebuilt by me with a lot of help from you guys. Thanks!
www.cardomain.com/ride/2980730
Re: 2.6l engine mounts [Re: sandhill_raider] #1006826 08/24/10 05:18 AM
TrailRaider Offline
You may want to have them check stock at the supplier. Anything I find for MB006605 is for a Galant/Lancer early model.
'89 Raider V6 auto.
Re: 2.6l engine mounts [Re: sandhill_raider] #1006827 08/24/10 03:24 PM
MI_Mitsu Offline
I've received bad mounts before. The locator nub or 'teet' was located in the wrong clock position. This was either a manufacturing or packaging mistake. I got them reshipped and they were correct on the 2nd go.
IIRC correctly, either 3.0 or 2.6 the mounts are identical L & R.
Not sure if this is your problem or not, but it happens alot with mis packaged parts. Also happened to me once with a caliper for the Montero. Correct caliper, but had wrong mount bracket.
Jim
Re: 2.6l engine mounts [Re: sandhill_raider] #1006828 08/24/10 09:13 PM
After multiple phone calls between Mitsu and Dodge dealers, here's what I found. The MB006605 is one of 3 mounts available for the 88 Montero, but not for the Raider. The MB260572 is the only mount for the Raider, but none of the 3 for the Montero. Here's the kicker, MB260572 is no longer available through Dodge, but Mitsu has 53 in a warehouse in Atlanta. And, the Mitsu dealer didn't want order them for me because they couldn't determine the number was correct for my truck. So, after I signed a statement in blood that I was responsible if the mounts didn't fit, two will be here Friday.
I still don't understand, and not sure I want to. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: 2.6l engine mounts [Re: sandhill_raider] #1006829 08/24/10 09:16 PM
Did you try checking the Mitsu ASA program yourself to see if the part's listed?
Re: 2.6l engine mounts [Re: off-roader] #1006830 08/25/10 02:47 AM
I haven't used that yet, been able to find most everything I need here on the forum. I'll check it out though. Looks like it could come in handy. Thanks
Re: 2.6l engine mounts [Re: sandhill_raider] #1006831 08/25/10 08:29 PM
MI_Mitsu Offline
IIRC ASA doesnt work with Raider VIN's. Neither do Conquest VINs. it has something to do with only accepting MMNA (Mitsu Motors North America?) car & truck VINs. Someone please correct me if I'm wrong...but I never got my 87 Raider VIN to work with ASA.
On the plus side, there are scans of the Dodge parts book featuring all the good cars (Raider, Conquest, etc) and a few forgettable ones (Colt, etc). It's in PDF and the parts are easy to find. I downloaded mine from a Quest site, but it's around.
Jim
89 Montero LS 3.0L/Auto
90 MightyMax 2.4L/Man
Parted/gone - parts available!
89 Montero LS 3.0L/Auto [Blue/Blue] (2 of 2)
89 Conquest SHP
88 Conquest SHP
87 Dodge Raider 2.6L/Auto
91 Montero RS 3.0L/Auto
Others: 37 Lincoln
Re: 2.6l engine mounts [Re: MI_Mitsu] #1006832 08/26/10 03:20 AM
TrailRaider Offline
I've got my big "flea-bay" special book here. '87-'88 raider both show MB260572 for the front mounts, stick or auto. Transfer support (small square one) for manual trans is MB007137 for both years and MB309700 ('87) or MB007136 ('88) for the main trans mount.
Same parts are shown for an '88 Monty 4 cyl stick on ASA.
MB007136 ('88) is also superceded MB309700 ('87)
So according to the Dodge parts book and the Mitsubishi ASA program there should be no difference between Raider or Monty mounts for '87-'88 4 cyl stick.
Hope this helps a bit. <img src="/forums/images/graemlins/cheers.gif" alt="" />
'89 Raider V6 auto.
Re: 2.6l engine mounts [Re: TrailRaider] #1006833 08/26/10 03:29 AM
TrailRaider Offline
Also scanned through the big book for MB006605.
Found it listed for '88 RWD Ram 50 and Power Ram 50.
Possibly used for other years, but my book is '87-'88 only.
'89 Raider V6 auto.
Re: 2.6l engine mounts [Re: TrailRaider] #1006834 08/26/10 04:01 AM
starquests were never in caps or asa, but were only on fiche at the stealers...
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6414 MB (Peak: 0.7666 MB) Data Comp: Off Server Time: 2026-10-22 00:09:45 UTC
