A Strange Occurance #1007152 08/27/10 12:42 AM
KB2IAW Offline OP
Driving home yesterday at about 55mph on a slight incline the montero lost power ..i coasted to a safe spot on the shoulder and could not re start the engine ...strong battery ,no overheating ,no light indicating anything .After about 5 mins the car started up stron and i went on my way...this occored two more times aftre that at about 20 miles apart or about 25 mins . I havent gotten a chance to get into it yet ...any ideas as to what i should look for ???any others expieriance anything simmilar ???
..Hate to bring in for service but if too difficult i may have to ....IDEAS PLEASE .engine with about 160.000miles ,cant remember the last tune up .??? <img src="/forums/images/graemlins/confused.gif" alt="" />
1994 montero SR 3.5 v6
City Of Hills Oneonta N.Y. FREEDOM HAS A TASTE,AND FOR THOSE THAT HAVE FOUGHT FOR IT, THE TASTE IS SO SWEET , THE PROTECTED WILL NEVER KNOW .
VENI VEDI DECI <oneontasportsmenclub.net>
Re: A Strange Occurance [Re: KB2IAW] #1007153 08/27/10 01:09 AM
zarktheshark Offline
what rig do you have? my first thought is vapor lock.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: A Strange Occurance [Re: KB2IAW] #1007154 08/27/10 04:03 AM
FrankR Offline
Start with replacin' the fuel filter.
Frank
Re: A Strange Occurance [Re: FrankR] #1007155 08/27/10 04:25 AM
ryany Offline
Modify your signature to include your vehicle and you'll get more useful responses. Not knowing whether you're dealing with a 1986 carbureted 2.6l 4 cyl. Gen I or a 2006 3.8l V6 Gen III makes any diagnosis pretty much a shot in the dark.
95 Montero SR
Re: A Strange Occurance [Re: ryany] #1007156 08/27/10 04:34 AM
sparkem Offline
If Gen1 v6, check your computer codes. Has the ECU ever been replaced?
Re: A Strange Occurance [Re: sparkem] #1007157 08/27/10 05:01 AM
A
airbats801 Offline
If it is the 2.6l It could be the carb. I had a carb on my 1984 spx which had a 2.6l and the carb started cutting out randomly on hills. I wiould have to wait a little while, then it would restart and run fine for another misc amount of miles and then cut out again. It mainly did it on hills
8 Starion SHP, 87 mitsubishi van, , 81 galant g54bt, 78 lancer g54bt, 1965 Mitsubishi Debonair Deluxe
87 swb montero offroad pkg goin g54bt with sr locker 33x12.5 dual bouncy.
Re: A Strange Occurance [Re: airbats801] #1007158 08/27/10 05:45 AM
two tests:
when it does it again, pour water over the fuel pump and engine compartment fuel lines, and see if that lets it crank right up.
plug the hose from the carb fuel bowl to the charcoal canister and see if that cures it.
Re: A Strange Occurance [Re: ryany] #1007159 08/27/10 04:00 PM
KB2IAW Offline OP
yikes my brains were so scrambled i forgot ...it`s a 1994 3.5 sr ...
IT`s In My Profile ...click on my signature (kb2iaw )
Re: A Strange Occurance [Re: KB2IAW] #1007160 08/27/10 04:25 PM
hazy_daze Offline
It makes it difficult for people to give you an answer if they have to investigate to find out what kind of vehicle you have. If you'll modify your signature (which shows up on this page so one doesn't have to click your screen name to view your profile) to include your vehicle, it'll make it easier for answers to be more quickly and accurately given.
Re: A Strange Occurance [Re: hazy_daze] #1007161 08/27/10 07:22 PM
Ditto.
You're asking people for help. Golden rule here is... Make it as easy for them to help you as possible.
Besides it's not too hard to add that to your sig and you don't have to show your sig with every post if you don't want to.
If you need help changing your sig, just let me know. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
BTW, any luck figuring out your problem?
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6421 MB (Peak: 0.7655 MB) Data Comp: Off Server Time: 2026-10-21 20:41:37 UTC
