Brake switch?? #1007267 08/28/10 12:26 AM
monty84 Offline OP
Hey guys my brakelights are out yet the bulbs are good and tailights work when headlights are on. Fuses are also ok, is there a brake switch somewhere in my truck or what else could be the problem? Thanks.
'84 Monty SWB, 2.6 Manual, rear LSD, bOuNcY, cranked T Bars, 33x12.5 M/T's
Re: Brake switch?? [Re: monty84] #1007268 08/28/10 12:50 AM
hazy_daze Offline
There's a stoplight switch at the pedal. A failing hazard switch can also occasionally cause this.
Re: Brake switch?? [Re: hazy_daze] #1007269 08/29/10 02:53 AM
monty84 Offline OP
Thanks hazy, I've looked for the switch down there but can't find anything, is it on the shaft, above the shaft where the wiring is, under the floorboard, etc.. And what would it look like? Thanks.
Re: Brake switch?? [Re: monty84] #1007270 08/29/10 03:04 AM
It's on the bracket. A flat on the pedal actuates it when all the way up.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6006 MB (Peak: 0.6561 MB) Data Comp: Off Server Time: 2026-06-20 17:39:36 UTC
