Grinding Starter - lost bottom bolt - pictures #1007344 08/29/10 11:08 AM
RobCambo Offline OP
Had a hell of a crunch from the starter on Friday and found that the bottom bolt was missing and the starter was loose as hell.
Got a new bolt in there now and re-tightened the top one, she's solid now, but the grinding is still there.
Started her up a few times: 3 times good, 2 times grinding, 2 good, 2 grinding. - all started the car.
On the last try I kept the key in start position and the starter got through 2 grinding episodes, turned normally for a second or 2 and she started up ok.
My question - Is it possible the flywheel was damaged when I lost the starter bottom bolt or is it that the starter is trashed?
Any advice much appreciated.
Rob
1986 Pajero 2.6l 5spd manual SWB
http://s690.photobucket.com/albums/vv265/RobCambo/
Re: Grinding Starter - lost bottom bolt [Re: RobCambo] #1007345 08/29/10 03:25 PM
Thats what it sounds like. That can't be good in Cambodia, what's it like finding parts?
Re: Grinding Starter - lost bottom bolt [Re: RobCambo] #1007346 08/29/10 05:15 PM
hazy_daze Offline
Most likely only the starter. The bendix is usually made of a softer material than the flywheel, so it'll give. It is possible that the flywheel teeth will be damaged after extended use of a broken-toothed starter...
Re: Grinding Starter - lost bottom bolt [Re: hazy_daze] #1007347 08/30/10 06:15 AM
RobCambo Offline OP
Thanks Hazy, that's what I was hoping to hear.
MudRaider: Can get parts here, but getting good parts is another ball game...
It'll be at least a week before I can get to fix this, and the car's my only daily drive - no real alternative. Here's hoping I don't mess things up using it.
Re: Grinding Starter - lost bottom bolt [Re: RobCambo] #1007348 08/30/10 02:06 PM
Can you park on hills so you can bump start it?
Re: Grinding Starter - lost bottom bolt [Re: MontyMcV] #1007349 08/30/10 03:27 PM
RobCambo Offline OP
Nope. Phnom Penh is mostly flat, and I park the car inside the house at night. Flat at work too.
I read somewhere there's an easy-to-reach shield underneath the car that when removed will allow me to see part of the flywheel - I'll be taking an assessment look on Wednesday.
The only way to get the flywheel to move is to turn over the engine, right? If I disconnect the battery and plugs, can I turn the engine over with a wrench or bar from someplace at the front end there?
Re: Grinding Starter - lost bottom bolt [Re: RobCambo] #1007350 08/30/10 03:49 PM
hazy_daze Offline
You can turn it via the crank bolt without taking anything else loose. And there is an inspection plate on it...
Re: Grinding Starter - lost bottom bolt [Re: hazy_daze] #1007351 08/30/10 04:12 PM
RobCambo Offline OP
Ahh, thanks again H. You're full of good news today <img src="/forums/images/graemlins/lol.gif" alt="" />
Stupid question time...Standing at the front of the car, do I turn clockwise or anticlockwise?
Re: Grinding Starter - lost bottom bolt [Re: RobCambo] #1007352 08/30/10 04:34 PM
hazy_daze Offline
Which side of the equator are you on?
<img src="/forums/images/graemlins/smile.gif" alt="" /> Counter clockwise, IIRC.
EDIT: Now I'm second guessing myself. Better wait for a second opinion...
Re: Grinding Starter - lost bottom bolt [Re: hazy_daze] #1007353 08/30/10 05:15 PM
Look at the fan. Turn the motor in the direction that pulls air to the rear...
Clockwise, IIRC...
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6450 MB (Peak: 0.7653 MB) Data Comp: Off Server Time: 2026-06-10 07:17:22 UTC
