Clearing 35s #1007434 08/30/10 07:54 PM
RatLabGuy Offline OP
'93 p/u...
What's the minimum lift needed on the front to clear "skinny" (e.g. 12.50) 35s? This is assuming that cutting sheet metal/fenders is no problem.
Could it be done w/ say BJ spacers and 2" BL if you cut the fenders back? I'm guessing the firewall seam is the problem?
Question Reality.
Re: Clearing 35s [Re: RatLabGuy] #1007435 08/31/10 01:50 AM
Rodgertheshrubber Offline
most of it depends on the wheel you are using. i had a set of bfg at 35x12.5 on stock steel wheels and cleared them pretty well with just trimming. i think they rubbed a bit on the pitman arm and idler arm at full lock. 3/4" spacer would take care of that. mostly you have to hammer back the seam as much as possible. i had a post on here when i first put the tires on that showed what needed to be cut and hammered dont know if it could be found...i now run a 1" bl and have cut the hell outta the fenders (more to get rid of the rust than to clear the tires). i also have bj spacers, but they are mainly for the extra little bit of travel. if you are not afraid of the hammer, 35s should fit on stock wheels. i will try to find that post
here she is although no pics :-( linky
"I am a shrubber, my name is Rodger the Shrubber. I arrange, design, and sell shrubberies"
Re: Clearing 35s [Re: Rodgertheshrubber] #1007436 08/31/10 03:58 AM
bkg Offline
4"
12.5's aren't skinny, though.
Brian K. Gallus
Re: Clearing 35s [Re: RatLabGuy] #1007437 08/31/10 07:33 AM
Snowtoy Offline
You can clear 35x12.50's w/a 2" BL, 1.5" BJ-Spacers, and some body seam adjustment. You may or may not need to cut the fenders, though likely most have to do some trimming.
On my '91 I have done the above as well as cut 2" out of the fenders. The fenders were dinged up and since I planned on SASing it at some point, I went ahead and cut off the 2"(welded on 1/8 wire to reinforce he lip).
The rims on it are 15x10's w/2.5" BS, 35x12.50 Xterrains and they clear under compression at full lock. I first had 315 BFG's on 15x10's w/3.5" BS on it, and they cleared as well.
Steering wheel at full lock(w/o holding it).
It might rub under a hard full compression, but I don't wheel that way.
Re: Clearing 35s [Re: Snowtoy] #1007438 08/31/10 09:19 PM
here are a coupla pics of mine since all my others are gone. its too bad i didnt get a shot of the other side but there is no rubbing anywhere.
1" body lift, bj spacers and some trimming and hammering
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6069 MB (Peak: 0.6731 MB) Data Comp: Off Server Time: 2026-06-20 19:19:58 UTC
