Rating: 5
Page 1 of 4 1 2 3 4
im done- 1989 going to Junk Yard, NorCal :( -IN YARD NOW #1007559 09/01/10 08:22 AM
G
greenchester Offline OP
UPDATE** This truck was taken to the yard today (09/25) Mowery PicknPull in Newark, CA. Hope some of you can get some good parts off of it.
Thanks for all the help and reachouts for help. THis truck WILL be missed. <img src="/forums/images/graemlins/frown.gif" alt="" />
I am very sad to post that the time has come for me and my 89 LWB to part ways. It is a gross polluter and the state run program repair guy could not figure it out. I pretty much replaced everything and he tracked it down to the computer not sending a spark duration signal every 6th time. We tried two computers and it did the same thing. All his tech guys in his network were just as confused.
So it is going to the yard once the CA says they will give me 1k for it. Very sad. Still a strong truck.
1989 LWB sunroof, bouncy seat, rebuilt top end (new heads 10k ago), new brakes, MC, fuel pump, fuel filter, plugs, wires, distributor. needs new steering box and some oil leaks. AC blows cold.
Very sad about having it end it but i'm at my wits end on this truck. Just letting you all know that it will be in the yard soon. I will repost to this when it is official.
I am willing to sell it to the highest bidder above 1k- but is is sold as is- no smog (b/c it don't pass)
'89 montero lwb
Re: im done- 1989 going to Junk Yard, NorCal :( [Re: greenchester] #1007560 09/01/10 08:53 AM
Happy Birthday hazy_daze Offline
Wow. 2 posts in almost 4 years. You didn't even give us a shot at helping you fix it <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Sounds most like it needs the optical sensor in the distributor. Or maybe a whole distributor.
Re: im done- 1989 going to Junk Yard, NorCal :( [Re: greenchester] #1007561 09/01/10 09:10 AM
E
evotechnik Offline
Can i get some parts from you??? Hazard switch and Bouncy seats? =)
Re: im done- 1989 going to Junk Yard, NorCal :( [Re: evotechnik] #1007562 09/01/10 06:29 PM
justice Offline
Distributer. Too bad your "tech" could not figure it out.
Re: im done- 1989 going to Junk Yard, NorCal :( [Re: greenchester] #1007563 09/01/10 06:44 PM
87Montero Offline
Maybe I should just fly out there and drive it back this way..
Got some pictures?
Re: im done- 1989 going to Junk Yard, NorCal :( [Re: 87Montero] #1007564 09/01/10 06:54 PM
RECON45 Offline
Here is one closer than going to Cali, but it stinks you did not ask all the gurus on here. I bet there is someone on here not to far away to take a look at it.
http://winstonsalem.craigslist.org/cto/1927023167.html
Re: im done- 1989 going to Junk Yard, NorCal :( [Re: justice] #1007565 09/01/10 09:15 PM
G
I admit this looks bad- very few posts from me and then I say I'm done!
A short history: bought with around 220k miles on truck (245k now)- its purpose is to go to Tahoe for snowboarding and trips to home depot and such- not a daily driver. It always had issues in the past passing smog so I ended up doing a top end rebuild- replaced the heads and fixes oil leaks and such. Biggish job, but not too hard.
About a year or so ago I replaced the distributor after it failed (would not send spark, truck would turn over, but not run)- It then later developed a hesitation- never thought it was a problem with the distributor since it was a new unit- I went thru every system check that was in the repair manual and replaced/renewed the following: Fuel pump and filter, plugs, wires, wiring harness for injectors, idle control valve, coil... even got a computer from the yard and it did not change the condition at all.
Then comes registration renewal and a Test only smog check is required. It fails- Gross polluter - which then allowed it to go into the state run repair program (I pay 100 bucks, state pays up to 500)- I take it to the best mechanic on their approved short list and he spends his time on it and tracks it down to the distributor. Puts in a new distributor and the problem does not change! I then give him my old computer and still no change. He posts the problems on his "official" mitsubishi forums and they are at a loss too. They say what is happening should no be b/c all the tests show that all the systems are working. He said that the computer tells the distributor to spark for a short duration for 5 out of the 6 times. The 6th time it just sends a ping out but no duration.
So I am not happy that it has come to this, but I have poured enough money into this truck. And it still needs a new steering box (300 bucks) to replace the loosey goosey leaking one in there now. And it still has oil leak issues and that damn metal heater hose leaks now and then.
I dont have the space now to part it out and mostly wanted to give a heads up to SF bay area guys that it will be in the yard soon.
I would love if it was just some simple fix.
I will post some pics when I get home from work.
'89 montero lwb
Re: im done- 1989 going to Junk Yard, NorCal :( [Re: greenchester] #1007566 09/02/10 06:17 AM
I have some parts in Placerville, or just donate it to the Ranch. <img src="/forums/images/graemlins/smile.gif" alt="" />
Russell
Re: im done- 1989 going to Junk Yard, NorCal :( [Re: greenchester] #1007567 09/02/10 06:19 AM
G
Here are pics- makes me sad/sick talking about it <img src="/forums/images/graemlins/frown.gif" alt="" />
'89 montero lwb
Re: im done- 1989 going to Junk Yard, NorCal :( [Re: greenchester] #1007568 09/02/10 06:25 AM
It just needs to be a dedicated trail rig. I have an extra distributor, if the optical sensor is faulty; you're welcome to try it.
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6442 MB (Peak: 0.7710 MB) Data Comp: Off Server Time: 2026-06-23 01:17:35 UTC
