stock rims that came w/ 31" factory option
#1007644
09/02/10 03:04 PM
On a 93 4Runner that came w/ the 31" factory tire option.... what are the specs of the rims they came on? Alloy or steel? 7x15, 3.75" backspacing?
Question Reality. ----------------------------- '89 Rnr DLX "SR4.5", 32s w/ 5.29 locked f/r blah blah
Re: stock rims that came w/ 31" factory option
[Re: RatLabGuy]
#1007645
09/02/10 03:29 PM
Theyre just SR5 rims. 15x7 4.75" backspacing.
Actually, you could get steel or alloy.
89 4Runner 3" BL, M/T locks, 33"bfg mt, bilstein, Kayline, tubebumper, toyotafiberglass panels TBI: Elocker,3.4 w/ORS,b+b,S2Sstg2cams,arias pistons,P+P intake,TRDs/c,URDpullies+7th,downey headers,MAPECU2,WEGO WB, SupraMAF,walboro255,stg4clutch, EPaOo2 sim
[Re: Greg_Canada]
#1007646
09/02/10 09:03 PM
Wow. I didn't realize the BS was that deep. So they could be either metal, eh? And a replacement that is 3.75 BS will add an inch sticking out. Hum.
[Re: RatLabGuy]
#1007647
09/03/10 01:55 AM
the alum ones look sooooo sweet, imho. i finally got a set about a month ago <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
"I am a shrubber, my name is Rodger the Shrubber. I arrange, design, and sell shrubberies"
[Re: RatLabGuy]
#1007648
09/03/10 03:28 AM
Wow. I didn't realize the BS was that deep. So they could be either metal, eh? And a replacement that is 3.75 BS will add an inch sticking out. Hum. Yeah it will stick out an inch more. I'm running 15x8 with 3.625 backspacing and they stick out over 2" more than stock. (1" wider plus 1.125" backspacing difference). 1" will be fine, not a big deal. will look alittle more aggressive. DO you have mud flaps? I find the farther the wheels stick out, the faster your truck gets dirty LOL... Mine: ![[Linked Image]](http://i148.photobucket.com/albums/s35/Greg_Canada/My%204runners/PICT0159.jpg)
[Re: Greg_Canada]
#1007649
09/03/10 06:05 AM
Well technically it's another guy's truck -but the "sticking out" is what I'm wondering about. Maryland inspection requires "fender must cover tires". Grrrr. Are the fender widths the same on 90s trucks and 4Runners?
Difference must be mostly the BS...if the tire is 10.5" across, dosn't THAT really set the functional width?
[Re: RatLabGuy]
#1007650
09/04/10 05:43 AM
Yes, the 2nd gen Runners and 3rd Gen trucks had the same width fenders. I am not sure if the DLX model runners came w/SR5 alloys or not, I know the trucks didn't, even w/the 31" tire package. The DLX trucks came with the steel wagon style wheels. ![[Linked Image]](http://img.photobucket.com/albums/v33/Snowtoy/Trail%20Pictures/18copy.jpg) I think a 15x7 w/3.5" BS would still keep you legal, the tread shouldn't be beyond the fender. Might be able to go w/a 15x8 and a 4" BS as well. He could always run some Warn fender flares to cover the tires. 15x8 w/3.5" BS and 32's look alright w/the Warn fender flares. That is how my truck was set up in this pic, back in '94. ![[Linked Image]](http://img.photobucket.com/albums/v33/Snowtoy/Trail%20Pictures/sc03612c96.jpg) This set-up also widens the stance a bit. ![[Linked Image]](http://img.photobucket.com/albums/v33/Snowtoy/Other/T90trk1.jpg)
[Re: Greg_Canada]
#1007651
09/04/10 05:28 PM
[quote]Yeah it will stick out an inch more. I'm running 15x8 with 3.625 backspacing and they stick out over 2" more than stock. (1" wider plus 1.125" backspacing difference).
[/qoute]
Actually, it should be 1.125" backspacing + 1/2 width of the wider wheel. 1" wider wheel only adds 1/2" to each side of the wheel centerline. So 1.125" from backspace and 1/2" from width = 1.625" wider.
Note - this does not take into acc't sidewall reaction to wider wheel. That can vary from tire to tire.
Brian K. Gallus I have nothing important to say.
