Steering gear upgrade? (Gen1 SWB) #1007700 09/03/10 07:14 PM
MartySoCal Offline OP
Is there an upgrade steering gear swap for an '86 SWB Gen 1? I remember seeing something about swapping in a Gen 2 or Gen 1 LWB box, but I'm search function illiterate on this site. <img src="/forums/images/graemlins/confused.gif" alt="" />
Should I swap in the Gen 2 pitman and idler arms at the same time?
My friend's steering gear has a leak, and it might be a good time to upgrade! There's a '95 Gen2 SR in the local junkard.
Re: Steering gear upgrade? (Gen1 SWB) [Re: MartySoCal] #1007701 09/03/10 07:45 PM
heathdogg Offline
http://www.4x4wire.com/forums/showflat.p...ue#Post1180844.
This was done by MarcDurant and should answer your questions.
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
Re: Steering gear upgrade? (Gen1 SWB) [Re: heathdogg] #1007702 09/03/10 09:08 PM
Kevin C Offline
He didnt swap the box... Just rod ends and idler arm.
Swapping the box takes a bit more effort since the upper holes are further apart on the later box. There is room to machine out the mount holes to match. I made up a set of oval spacer to go under the bolt head.
web page
Kevin
Re: Steering gear upgrade? (Gen1 SWB) [Re: Kevin C] #1007703 09/03/10 09:34 PM
FrankR Offline
Kevin, did you find any advantage to using that box?
Frank
Re: Steering gear upgrade? (Gen1 SWB) [Re: FrankR] #1007704 09/03/10 10:23 PM
heathdogg Offline
Guess it would have helped if had learned to read in school. Sorry
Re: Steering gear upgrade? (Gen1 SWB) [Re: FrankR] #1007705 09/03/10 10:31 PM
Kevin C Offline
Frank
The biggest advantage is it has a faster steering ratio. It's also a stronger box, but I dont think that a signifigant advantage on my 4 cyl SWB gen 1.
The faster ratio does take some getting used to, but I really like it esp when making sharp turns at the loading area at Home Depot (just came back from there).
Re: Steering gear upgrade? (Gen1 SWB) [Re: Kevin C] #1007706 09/03/10 10:39 PM
Is the LWB Gen 1 box different from the SWB? (Different bolt pattern like the gen 2 box, lock to lock turn count, bigger internal piston for less effort, etc.) Any advantage to it?
I read on the Gen1-Gen2 swap sticky thread that the idler arm is stronger on the Gen 2 vs the Gen 1, but the arm itself is slightly longer. If I use the Gen 2 box with the Gen 2 pitman arm and idler arm, other than a slight toe change and a slight decrease in lock to lock turns, (If the arms are indeed longer) any disadvantages, advantages, or clearance issues?
Thanks for the answers so far! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Steering gear upgrade? (Gen1 SWB) [Re: MartySoCal] #1007707 09/03/10 10:53 PM
Kevin C Offline
Marty,
This is going to sound really bad.... But I dont really remember what I got my steering box out of. I'm pretty sure it was a 90 or a 91, four door. I must have been a Gen 1 since it was the doner for the front axles. I did the steering box swap about 8 years ago, so my memory is a bit fuzzy on the details.
I know it has the same lenght pitman arm.
Kevin
Re: Steering gear upgrade? (Gen1 SWB) [Re: Kevin C] #1007708 09/04/10 12:26 AM
MI_Mitsu Offline
An 89LWB gearbox is slightly different from a 90-91 Gen 1 gearbox. the main pitman shaft that connects to the pitman arm is a different diameter... 90-91 being a little larger diameter (beefier) also requiring a different part number pitman arm. I believe the ratio's are nearly identical. Otherwise the gearboxes are the same for 89 to 91 for LWB. I have an 87SWB out back, but havent compared it's gearbox yet to either of the LWb sets I have.
89 Montero LS 3.0L/Auto
90 MightyMax 2.4L/Man
Parted/gone - parts available!
89 Montero LS 3.0L/Auto [Blue/Blue] (2 of 2)
89 Conquest SHP
88 Conquest SHP
87 Dodge Raider 2.6L/Auto
91 Montero RS 3.0L/Auto
Others: 37 Lincoln
Re: Steering gear upgrade? (Gen1 SWB) [Re: heathdogg] #1007709 09/04/10 01:09 AM
Kevin C Offline
And some days my writing skills are pretty bad. Beetween our two posts we kind of had it covered.
That works for me.
Back to the cellar to do some more digging. <img src="/forums/images/graemlins/barf.gif" alt="" />
Kevin
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6354 MB (Peak: 0.7440 MB) Data Comp: Off Server Time: 2026-10-21 20:44:55 UTC
