Gen 2 Front Axle Into a Gen 1 #1008527 09/13/10 04:11 AM
SRTNate Offline OP
It fits...
This is using the Gen 1 brackets and crossmember. The brackets mount to the axle in exactly the same way, but the Gen 2 chassis mount points are completely different.
The crossmembers are close, but the chassis mount points are a fraction of an inch different, so I used the Gen 1. The crossmember-to-axle mount points are close, but also different. I used the Gen 2 axle mount, and will find a way to attach it to the crossmember...I will probably just be lazy and weld it on.
Gen 1 Top/Gen 2 Bottom
The Axle widths are the same...
Covers
Gen 2 Left/Gen 1 Right
...and here is a pic to illustrate the difference between High and Low pinion diffs.
Gen1 Left/Gen2 Right
I have test fit the 3.5L on top of the G2 axle, and it still fits...in fact I may not have had to modify the oil pan. I can't say for sure what 3.0L or 2.6L oil pan clearance would be like.
I also am not sure how I'll use the Center Axle Disconnect. I see a few options:
  • Use the CAD as intended with vacuum and solenoid control
  • Remove the diaphragm, and use a push-pull cable to actuate the CAD
  • Physically (not electrically) wire the CAD so it is always engaged (I have manual hubs)
  • I'm not sure, but willing to bet this would work: Remove the CAD internals and just use the Gen 1 stub axle
So, there's something to think about...I'm open to suggestions.
I am also now on the lookout for a set of 4.90's, now that I have G2 front and rear axles.
1989 Mitsubishi Montero SWB 0.0L (3.5L soon?) Auto, Front LSD, Rear SR Locker, Aisin hubs, Safari Snorkel, ARB Front Bumper, Warn M8000, Bushwacker Flares
1984 Mitsubishi Montero
2005 Dodge SRT-4
1970 Plymouth 'Cuda (in pieces)
...and a few others less interesting.
Re: Gen 2 Front Axle Into a Gen 1 [Re: SRTNate] #1008528 09/13/10 01:26 PM
W
willwinchforfood Offline
And soon to be tested on a stock Gen 1 with 3.0... Soon
John
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
Re: Gen 2 Front Axle Into a Gen 1 [Re: willwinchforfood] #1008529 09/13/10 03:00 PM
justice Offline
One thing to look at is the stub axle flange(where the CV bolts on). I found the bolt pattern to be larger on the gen 2. If you swap to the gen 1 axle it should not be an issue.
Good job on this!
Re: Gen 2 Front Axle Into a Gen 1 [Re: SRTNate] #1008530 09/14/10 05:01 AM
Codyaku Offline
haha nice. i asked that question a while ago about swapping the diff. For the gen one diff i was wondering if i can connect a hose to the breather and run it up higher in the engine compartment?? or would it be better to get the gen II diff cover?
1990 Montero lwb, 3.0 V6, Custom bull bar, Completely stock on everything else. 186,000 miles
2" inch torsion bar lift. Conferr roof rack with homemade gutter mounts.
Re: Gen 2 Front Axle Into a Gen 1 [Re: Codyaku] #1008531 09/14/10 05:34 AM
SRTNate Offline OP
The Gen 2 cover does have a nice little fitting on it, but it's not the most amazing thing ever...you could put a hose barb on the Gen 1 cover pretty easily.
2005 Dodge SRT-4
Re: Gen 2 Front Axle Into a Gen 1 [Re: SRTNate] #1008532 09/14/10 02:33 PM
hazy_daze Offline
The search function results beg to differ with you....
It sh!ts rainbows as far as I'm concerned...
Re: Gen 2 Front Axle Into a Gen 1 [Re: hazy_daze] #1008533 09/14/10 06:20 PM
SRTNate Offline OP
Lol, I just meant it's 6 of 1, 1/2 dozen of another. You could go to a parts yard and track down a Gen 2 cover, or go to a hardware store and get a barb. You've gotta run a length of tubing either way.
2005 Dodge SRT-4
Re: Gen 2 Front Axle Into a Gen 1 [Re: SRTNate] #1008534 09/17/10 12:33 AM
KrzyDav Offline
how much longer does that "strech" your front driveshaft???
dave h.
Re: Gen 2 Front Axle Into a Gen 1 [Re: SRTNate] #1008535 09/17/10 01:58 PM
MartySoCal Offline
Can you post a picture of the right side axle shaft differences and disconnect parts too? Thanks for the great post! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Gen 2 Front Axle Into a Gen 1 [Re: KrzyDav] #1008536 09/18/10 12:25 AM
KrzyDav Offline
This project has peaked my curiosity.
Looking under mine last night I have a few observations/questions.
It looks like the driveshaft might hit the clutch slave. Have you put the trans into its normal position , as if the engine were in , to see if slave clears.
Man, not much room to work on exhaust pipes around there either.
Quite a few M.S. 4.9 high pinion pumpkins out there in the yards. Hope this all works out <img src="/forums/images/graemlins/kewl.gif" alt="" />.
dave h.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6443 MB (Peak: 0.7695 MB) Data Comp: Off Server Time: 2026-06-07 07:26:07 UTC
