Gear interchange w/ Supra #1008841 09/17/10 06:27 PM
RatLabGuy Offline OP
I know this is an oddball question, but bear with me.
Does anybody know if the R/P gears from the truck drop-out 8" differentials also match the dimensions of the Supra/Cressida 8" IRS differential?
I know the carriers are the same, due to the supra-LSD swap.
Which makes me hopeful, the ring must at least be close. But given the different style of teh housing, I could also easily see the pinion shank, the gear size, or lash etc being different.
In short - could you fit say "truck" 4.88s into a Supra IRS?
(Paging Dr. Zuk....)
Question Reality.
Re: Gear interchange w/ Supra [Re: RatLabGuy] #1008842 09/17/10 07:25 PM
G
Greg_Canada Offline
OEM 4.88's or aftermarket?
Best idea would be to call Randy's Ring and Pinion... they should know....
89 4Runner
Re: Gear interchange w/ Supra [Re: Greg_Canada] #1008843 09/17/10 09:36 PM
Don't really care, just so the gearing matches... say... another axle on a truck <img src="/forums/images/graemlins/kewl.gif" alt="" />
I checked Randy's website, they don't list any parts for the Supras.
My guess is, there is a supply/demand issue here.
I mean, what nutjob in their right mind would want to put 4.88s in their supra? <img src="/forums/images/graemlins/nana.gif" alt="" />
Question Reality.
Re: Gear interchange w/ Supra [Re: RatLabGuy] #1008844 09/18/10 10:05 AM
Snowtoy Offline
Try Jawsgear, he also builds Supras.
Thinking of using an MKIII 8" diff, or the larger MKIV(8.6") diff in place of the 7.5" diff?
Given the weight of the Supra(especially the MKIII), 4.88's would work good for a road course track car or 1/8mile(might be just a bit tall), the taller gear would keep the rpms up, negating turbo lag.
Re: Gear interchange w/ Supra [Re: Snowtoy] #1008845 09/18/10 06:34 PM
MKIII, yes. What has been dubbed as the "supralux" swap. Haven't foudn alot of info on it. Seems pretty straightforward - aside from changing the diff, you have the CVs to worry about. But teh advantage is, much better CV angle... less breakage. Plus you can get an LSD basically for free.
But I want to be sure I owuldn't be stuck w/ the stockl 4.10 gearing of those IRS diffs.
According to Precision Gear, the same model R/Pset is for pickups, 4runner,s nad Turbo/v6 Supras 79-95... so that's good news.
Question Reality.
Re: Gear interchange w/ Supra [Re: RatLabGuy] #1008846 09/19/10 04:22 AM
Snowtoy Offline
This gear swap post on Supra Forums might be helpful. Might check out MKIII Tech.com as well.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6110 MB (Peak: 0.6978 MB) Data Comp: Off Server Time: 2026-06-07 08:39:42 UTC
