Gen1 pajero non LSD to LSD swap question #1009142 09/20/10 03:20 AM
N
nabsie Offline OP
I have a gen 1 with a non LSD rear diff and want to do a swap to one with LSD.
The LSD diff is a gen 1 also and also from a 2.5l diesel. Same as my vehicle.
Do I need to replace the drive shafts with those from the LSD or is it as simple as swapping the 3rd member (diff housing)?
Thanks for the help.
90 SWB 2.5 TDi Pajero, 31x10.5 BFG A/T on 15" Two Piece BERG rims, ARB steel bull bar, Narva Headlight Upgrade, Thule Racks and Basket.
Re: Gen1 pajero non LSD to LSD swap question [Re: nabsie] #1009143 09/20/10 04:03 AM
Should be a straight chunk swap, axles and driveshaft all the same. The only difference is in the side gear housing...
Re: Gen1 pajero non LSD to LSD swap question [Re: nabsie] #1009144 09/20/10 08:26 PM
Chief Offline
The LSD carrier has a "thrust" washer in the center, and the axle shafts form a non LSD may be too long. On mine they were aprox. 1/8 inch (about 4mm) longer.
I'll advise you to measure them before hand.
Other wise the third member should bolt right up.
'89 Raider V6, AT, SAS'ed, Dana 44 front & rear, 5:38 gears, NP 231 T-case.
'97 Montero SR, cold weather package, 4.90 R&P, BATTLEZ suspension w/ 2" lift, JAOS grill guard & under body protection, custom rock sliders.
Re: Gen1 pajero non LSD to LSD swap question [Re: Chief] #1009145 09/21/10 12:12 AM
N
nabsie Offline OP
I ended up picking up 93 gen 2 rear axle complete from disc to disc on eBay for $50 !! Not only do I get LSD now but also disc brakes and more heavy duty trailing arms.
The wrecking yard wanted $175 for the third member alone.
I did get some aisin manual locking hubs from the wrecking yard for $66 for the pair.
Re: Gen1 pajero non LSD to LSD swap question [Re: nabsie] #1009146 09/21/10 05:22 PM
W
willwinchforfood Offline
does the 93 have the right gears?
John
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
Re: Gen1 pajero non LSD to LSD swap question [Re: willwinchforfood] #1009147 09/22/10 01:25 AM
N
nabsie Offline OP
Yeah I confirmed the ratios matched before purchasing.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6081 MB (Peak: 0.6775 MB) Data Comp: Off Server Time: 2026-06-21 20:24:34 UTC
