Re: gen 1 cutting out in water problem [Re: Jamez] #1009311 09/23/10 08:57 AM
DocPaj Offline OP
ok, so its only when i go through a puddle or muddy water pit with a little speed to try and get through faster. if i go slow it doesnt cut out strait away but it will when i have to floor it to get out the other side. little puddles like a foot or 2 deep are ok if i go slow'ish but anymore than that no matter how fast or slow i go it stops running!! what i mean by cutting out is it splutters for a few seconds then its like its not getting fuel or spark and just dies. i usually give it like 2-3 mins before i try start it again, it takes a couple of goes but it starts then runs funny for the next few mins, after that its fine again, till the next water hole!
i'm all out of ideas, i just go through the water now and deal with the issues at the other end of it!!!
Mick
'89' LWB V6 EFI, AUTO, FACTORY 'LSD', SUNROOF(dont work), UHF, RHINO RACKS, WOUND TB'S, GU COILS, REAR SWAY BAR DELETE, 31' M/T's ON 15X8 PATROL OFFSET SUNNYS, 2.5" SPORTS EXHAUST = FUN FUN FUN!!!!
Re: gen 1 cutting out in water problem [Re: DocPaj] #1009312 09/23/10 02:54 PM
hazy_daze Offline
The easy solution is to stay out of the water <img src="/forums/images/graemlins/ignore.gif" alt="" />
Sorry, I couldn't resist.
Re: gen 1 cutting out in water problem [Re: hazy_daze] #1009313 09/23/10 03:15 PM
MarkG Offline
  • Start up the truck.
  • Open the hood (or bonnet or whatever you call the big flat piece of metal). <img src="/forums/images/graemlins/ignore.gif" alt="" />
  • Get a water hose and start spraying things on/around the engine.
You may just find out where the problem is. At least, you can wash the dirt off the engine. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: gen 1 cutting out in water problem [Re: MarkG] #1009314 09/23/10 04:38 PM
zarktheshark Offline
so, up to 2 ft you are fine if you go slow. so, i'm thinking, what does water touch after that. oil pan, starter, radiator fan. the fan is going to to throw water all over. I can't see water on the ignition compents bein the problem because you have them sealed and the problem goes away after a few minutes. for me, I always have to dry it off to get it to run again. so, what's up top that can get wet and dry well enough to start running again? altinator? what about electircal connections coming through the fire wall? could the rapid cooling of some component cause the computer to think that is has to enter cold start mode? I'm just pulling stuff out of my <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> now, cuz I'm just as stumped as you. good luck.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: gen 1 cutting out in water problem [Re: zarktheshark] #1009315 09/24/10 10:39 AM
DocPaj Offline OP
well, im stumped tooooo!!! i have tried a hole heaps of things and asked whoever i meet that is into cars, i even asked an auto elec and he had no idea either, so i guess im just gonna get some rubber gloves and start covering sh1t up!! cant think of anything else that i can do to make this problem go away!!!
keep the idea's flowing tho, you never know!!!!!
Re: gen 1 cutting out in water problem [Re: DocPaj] #1009316 09/24/10 07:12 PM
hazy_daze Offline
Have you done what several people have suggested and sprayed individual components til you find the offender? You keep asking for more ideas, but you haven't said that you've tried this...
Re: gen 1 cutting out in water problem [Re: hazy_daze] #1009317 09/25/10 12:45 AM
DocPaj Offline OP
yeah, i have done this and when i did nothing really happend till i got to the top of the engine and wet the coil and then it started playing up, but then by that time i had water all over the engine and it could have leaked in from anywhere else, i had the coil replaced at that time anyway but it still does it with new coil so it cant be that. i am going to book it in at an auto elec next week and see if they can sort it, coz i cant.
Re: gen 1 cutting out in water problem [Re: DocPaj] #1009318 09/25/10 01:09 AM
redsput Offline
I had the same thing on my Gen 1 v6. Turned out it was a bad coil, spark jumping right out the side. I found this when spraying a bit of ether to get her running after a deep dip. Squirt, poof, flames!
89' v6 5-speed Raider 33's (toy)
95' LS Montero (the tow mule and workhorse)
87' 2.6 Raider (in process)
88' 2.6 Montero 2 dr (in process)
88' 2.6 Raider (organ donor)
89' 2.6 Power Ram [D50] Jr's wheels
Re: gen 1 cutting out in water problem [Re: redsput] #1009319 09/25/10 11:58 PM
DocPaj Offline OP
that is what i thought it was after pouring water over it, but i have changed it and it still does the same thing.
good to see that its not just me that has had this problem tho!!
Re: gen 1 cutting out in water problem [Re: DocPaj] #1009320 09/27/10 12:35 AM
MarkG Offline
Was the replacement coil new?
What about the wires to/from the coil?
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.011s) Memory: 0.6431 MB (Peak: 0.7685 MB) Data Comp: Off Server Time: 2026-11-19 23:54:12 UTC
