4cyl LSD: whole axle or just guts? #1009742 09/28/10 02:48 PM
djacidjac Offline OP
I think I found an LSD for my Raider. Is it easier or better in any way to grab just the LSD, or the whole axle? They are self-contained, right?
87 Dodge Raider 5sp 2.6l no jet valves, Tuffpan
OME Dakar leaf springs + T-bar crank + 2" body lift (4" lift).
5500lb winch, Starion alternator, grp31 marine bat'
OBA (stock AC compressor)
33x12.5x15 Baja Claws or Wintermark extra load 235/75/15 M/S
Re: 4cyl LSD: whole axle or just guts? [Re: djacidjac] #1009743 09/28/10 05:03 PM
Grasscat Offline
I would just grab the pumpkin. It's about the same effort, but a whole lot less weight to mess with. Plus you already know what you have back there now, brakes, etc.
Michael j
TreadLightly! Trainer
Re: 4cyl LSD: whole axle or just guts? [Re: Grasscat] #1009744 09/29/10 12:22 AM
N
nabsie Offline
About to do this swap also.
I ended up picking up a whole rear end from a 93 Gen2 V6 3.0L LWB. Which is the same as a Gen1 NG LWB 3.0L
My truck is a 90 2.5TDi SWB so the benefits for me are LSD, Disc Brakes, 9" vs 8" and I think the trailing arms are beefier also. I will stick some Gen 1 LWB rear springs in at the same time for 1.5" lift.
Junk yard wanted $175 for just a pumpkin and I picked up the whole rear end from ebay for $56.
Be sure to double check the ratios before you buy anything.
90 SWB 2.5 TDi Pajero, 31x10.5 BFG A/T on 15" Two Piece BERG rims, ARB steel bull bar, Narva Headlight Upgrade, Thule Racks and Basket.
Re: 4cyl LSD: whole axle or just guts? [Re: nabsie] #1009745 09/29/10 12:37 AM
The ratios match (4.625). They want $200 and will only sell the whole axle. That seems steep. Is it a rip-off? Should i counter offer $50? I think it's rear drum brakes so the only upgrade is the LSD -as is.
Re: 4cyl LSD: whole axle or just guts? [Re: djacidjac] #1009746 09/29/10 12:56 AM
KrzyDav Offline
maybe a better option would be to get a rear axle from a 97-99 Montero Sport. They have rear leaf springs for easir swap, LSD, disc brakes, 4.36 ratio (close enough), and a 3 inch wider axle.
I don't know if spring pearches are exactly the same , might check on that first .
dave h.
Re: 4cyl LSD: whole axle or just guts? [Re: djacidjac] #1009747 09/29/10 02:10 AM
N
nabsie Offline
Sucks that they wont just sell you the pumpkin. Seems a bit of a waste to buy the whole thing when you only need one part. Mainly just due to the size of it. Getting rid of the empty axle would be a pain in the <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
The junk yard I went too wanted $275 for the entire rear axle, so realistically $200 is pretty good. I do live in Australia ....dollar is pretty like for like at the moment though.
You could counter $50 but I dont like your chances. 75% discount! Maybe $100.
How many miles or km's are on the axle?
The one I looked at for $275 only had 75,000 miles.
The one I bought for $56 has 136,000 miles.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6102 MB (Peak: 0.6804 MB) Data Comp: Off Server Time: 2026-06-20 19:19:59 UTC
