water leaking out between block and head #1009808 09/30/10 02:51 AM
ghostwalker Offline OP
guys i rebuilt my 3.5 sohc engine and now its got about 7k on the motor and now its leaking a small amount of water out between the block and the head on the passger side its not leaking water into my oil yet wonder if i can retighten the head bolts or will i have to replace the head gaskets it not loseing power or any thing like that please tell me what i should do
do you feel lucky
Re: water leaking out between block and head [Re: ghostwalker] #1009809 09/30/10 02:56 AM
LandRaider Offline
I'd check every freeze plug, coolant hose, and fitting for leakage first, and then if I absolutely determined that it was coming from between the head and block, I would Re-torque the bolts. nothing to lose there.
Good luck. let us know how it goes. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: water leaking out between block and head [Re: LandRaider] #1009810 09/30/10 03:14 AM
i have checked it and i can see the water tricking out when it idleing do you think retourgeing the head bolts will help
do you feel lucky
Re: water leaking out between block and head [Re: ghostwalker] #1009811 09/30/10 06:39 AM
A
airbats801 Offline
my friends starion started leaking out the rear water port from the hg. Wasnt leaking into the cylinder or oil. Make sure thats where it is coming from. Try retorqueing the head first, otherwise you will need to change the hg. Is it spraying ior just dribbling when it's warmed up? If it's a spray you will wanna get it fixed soonmer and layer otherwise you will end up with a channel in the block or head eventually.
8 Starion SHP, 87 mitsubishi van, , 81 galant g54bt, 78 lancer g54bt, 1965 Mitsubishi Debonair Deluxe
87 swb montero offroad pkg goin g54bt with sr locker 33x12.5 dual bouncy.
Re: water leaking out between block and head [Re: airbats801] #1009812 09/30/10 02:30 PM
its not spraying its just a very slow seepage but i lose about one quater quart of water a day i dive 10 miles to work and 10 miles homme
do you feel lucky
Re: water leaking out between block and head [Re: ghostwalker] #1009813 09/30/10 10:25 PM
KrzyDav Offline
My shortblock 3.0 from defunct Densmore Engines had a SAE drain plug in it instead of British or metric(whatever they use). While on a long trip the Permatix 1 they used washed out. The leak wasn't visable under the Ex manifold ithout removing starter. The deal had the plug.
dave h.
Re: water leaking out between block and head [Re: KrzyDav] #1009814 09/30/10 11:14 PM
FrankR Offline
AFAIK, all of the oil and water drains on the 3.0L are SAE pipe taper as supplied from the factory. The 4 oil gallery plugs are 3/8" PT and the 2 water drains are 1/4" PT.
Frank
Re: water leaking out between block and head [Re: FrankR] #1009815 10/01/10 03:38 AM
My best guess is that the head gasket got pinched on install, probably by getting the head dropped on it. I'd go back to the rebuilder.
Re: water leaking out between block and head [Re: fasteddy] #1009816 10/01/10 05:04 AM
mxmikie Offline
i think i have a head gasket set for this
Re: water leaking out between block and head [Re: fasteddy] #1009817 10/01/10 05:38 AM
i am the re builder loll
i reused the head bolts after the guy at the machine shop told me i could reuse um guess he was wrong plus i didn't use no copper coat on um i know i should have now this was my first montero motor i have ever rebuilt
do you feel lucky
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6420 MB (Peak: 0.7616 MB) Data Comp: Off Server Time: 2026-06-21 00:09:01 UTC
