Re: water leaking out between block and head [Re: ghostwalker] #1009818 10/01/10 11:10 AM
FrankR Offline
The head bolts are reuseable and require no copper coat or any other sealant. They do require a torque value of 80 lb-ft, a thorough cleaning of the deck holes with a bottoming tap plus a check for clamping range and a possible grinding of the bolts for any length issues.
Frank
Re: water leaking out between block and head [Re: FrankR] #1009819 10/01/10 02:47 PM
ghostwalker Offline OP
thanks guys i am going to replace the head gaskets and head bolts that should fix it i do all my own work so its no big deal thanks guys
do you feel lucky
Re: water leaking out between block and head [Re: FrankR] #1009820 10/02/10 12:35 AM
KrzyDav Offline
I figured maybe it had the British Pipe thread like on the oil filter adapter for the oil gauge. How about some consistancy Mitsubishi?
Well maybe Densmore put metric threaded plug in. Anyway they were the wrong thread. That's not all they did wrong on this rebuldt shortblock,,,that's why they are out of business , I recon...
dave h.
Re: water leaking out between block and head [Re: ghostwalker] #1009821 10/05/10 04:59 AM
well guys i ordered all new head bolts and head gasket set along with upper gasket set now i just have to waite on all of the parts to be delivered
do you feel lucky
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6084 MB (Peak: 0.6803 MB) Data Comp: Off Server Time: 2026-06-07 11:36:55 UTC
