Manual hub swap on the cheap... #1009841 10/01/10 03:13 AM
9
97sport Offline OP
Hey, guys! I'm new to the site, but thought I'd share recently acquired. I've owned a 97 Sportage for about 8 months now. well, for the last few months I've been running around the desert with blown hubs (a lack of 4wd is liveable here in the summer).Well, with Winter right around the corner I figured I ought to fix those damn hubs.
Got to lookin around at the Warn Manuals, but the price is kinda steep in my economic state. Did a little research and found all the Vehicles that used manual hubs with sililar mounting styles, spline counts, and diameters. After getting an idea of what would be close and what to look for I took a trip to the local wrecking yard to try a few out.
First were factory Aisin hubs off an early Mazda B2600. Found out that if you use the wheel bearing hardware off the Mazda, the hubs themselves, and the six hub bolts per side they bolt right on! One modification does have to be done though... There is two dowel-pins on the mating surface on the back of them. These can either be cut off, ground flush, or a machine shop can pull them out.
They've been on two weeks now and not a single issue!
Hubs-$18/pair with all hardware
Cutting wheel and grinder-$borrowed 'em
Grease to repack bearing while I had it apart anyway-$8/tub
Total-$26
Try it out.
Pictures and write-up on the way...
'97 Sporty, 4wd/MT- Mazda/Aisin manual hubs, ghetto cold air intake. Planning- Mechanical OD auto/Dana 300 swap, SAS, and a little tooob...
Re: Manual hub swap on the cheap... [Re: 97sport] #1009842 10/01/10 03:59 AM
DennisThompson Offline
Great info, I have heard something about that before, it's nice to know someone tried them.
Thanks, Dennis
Re: Manual hub swap on the cheap... [Re: DennisThompson] #1009843 10/01/10 04:51 AM
Everet Offline
Ditto on the info.
Was wondering what year exactly?
Need to spread this knowledge.
Everet
<img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Manual hub swap on the cheap... [Re: Everet] #1009844 10/02/10 01:08 AM
minydigger Offline
definitely post up some more info I would love to get some manual hubs on the cheap.
94 Zj custom suspension and other stuff
01 F250 tow hoe 5" exhaust
00'sporty 3" lift 235's
Re: Manual hub swap on the cheap... [Re: minydigger] #1009845 10/02/10 03:46 AM
Everet Offline
I think I read a post about doing this but did not mention changing the front bearing.
What is different that requires the need to change the bearing?
Re: Manual hub swap on the cheap... [Re: minydigger] #1009846 10/02/10 03:54 AM
9
97sport Offline OP
You're looking for an older (87-89?) non-injected B2600. Not the newer fuel-injected I model. The earlier trucks had manual hubs, while the later models had drive flanges and an vacuum controlled CAD. Anybody still having problems with breaking hubs could always swap on those later drive flanges...
Ya gotta remember though, these are Aisin hubs. Known by the Toyota guys to be insanely strong, these hubs are bomb-proof when compared even to the Warns.
These guys have a billet steel body, cast aluminum cap, and are huge compared to the Warns tiny cast aluminum body. I doubt this little 2.0 will ever break another hub. Something else would let go first...
Re: Manual hub swap on the cheap... [Re: Everet] #1009847 10/02/10 04:13 AM
9
97sport Offline OP
Sorry man, didn't read this...
You need the wheel bearing hardware because the key that fits in the keyway in the spindle to keep the wheel bearing nut from backing off is built into the lock rings that engage the automatic crap...
I don't know about going from other manual hubs to these. I swapped it because it's cheap and fits like factory. Grabbed the parts with the hubs and gave it a try...
The Mazda wheel bearing hardware is also extremely easy to work on, only requiring an 8mm 1/4" drive socket and ratchet (to remove the lockring), and a spanner to adjust the wheel bearing preload. Less tools to carry in the brush is nice too.
Re: Manual hub swap on the cheap... [Re: 97sport] #1009848 10/02/10 05:34 AM
Everet Offline
Hope to see the pictures soon.
Pins appear to be dowel pins that should come out with vise grips but maybe not.
Where did you get them so cheap?
car-part.com would be $50+ shipping is the best I've seen.
Thanks for the update.
Re: Manual hub swap on the cheap... [Re: Everet] #1009849 10/19/10 01:04 PM
kiaracer Offline
i'm not sure if i understand why you need the wheel bearing hardware. pictures would be great.
2000 Kia Sephia, 1998 Kia Sportage 4x4, 2002 Kia Sportage 4x4
Re: Manual hub swap on the cheap... [Re: kiaracer] #1009850 10/28/10 03:33 PM
minydigger Offline
what happened to the pics Im a visual kinda person.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6421 MB (Peak: 0.7632 MB) Data Comp: Off Server Time: 2026-07-09 16:19:01 UTC
