new to the sportage world one question #1010012 10/03/10 03:07 PM
F
flaco Offline OP
I'm not to interested in spending the money on doing the lift "yet" considering I live in Chicago which is mostly flat roads and about 0% of my driving is done off road... But that said I do want a slight appearance of meaty tires so I was looking at General Grabbers and was curious if I can fit 215/75/15 or can it only take the exact oem size of 205's..... I went through the main lift sticky and gave up after about an hour to see if this was mentioned already...
What is the largest tire size I can fit on my completely stock, 2000 sportage 2 dr. 4x4
Re: new to the sportage world one question [Re: flaco] #1010013 10/03/10 03:50 PM
hadtomer Offline
235/75R15
2001 sporty. 4 inch lift+ body lift-front lovlells coils+extended forks. reat tj. monroe shocks. full skid plate, auxilary fan. external oil cooler. maxxis 8060 235/75 R15 tires on american racing wheels. trackfinder rear diff lock.
http://www.cardomain.com/ride/3948684/2001-kia-sportage
Re: new to the sportage world one question [Re: flaco] #1010014 10/03/10 10:21 PM
DennisThompson Offline
I ran 215/75/15 for years before I did my lift, no isues at all. No rubbing, no power loss and no MPG increase. Looked good on a stock Sporty also.
Dennis
Re: new to the sportage world one question [Re: DennisThompson] #1010015 10/03/10 11:02 PM
Sportege_Panicmech Offline
205/75/15 OE
215/75/15 1 step up
225/75/15 2 steps up
235/75/15 3 steps up Stock for many small suv's/trucks
Can also go wider and maintain OE height with
225/70/15 Stock size for Ford Escapes. I did this with mine and it cornered soo much better than oe.. I used continental truck/suv.
Or go a tad higher and max width on stock rim with
235/70/15 won't find an suv/truck style tire. this is usually a street race tire size for hot rods
simple tire size math.. 1st oe numer is 205. that's 205mm tire width. the next number is 75.. 75% width=sidewal height. the 15" is obviously rim size. so to go from 205/75/15 to 215/75/15 is 1 step higher and wider. 225/75/15 is 2 steps higher and wider. 235/75/15 is the 3rd step higher and wider. All threse will work. 235/70/15's rub on mine (just hard turns/bumps.. livable), but that's cause they are mud tires.. same size in an all-terrain probably would clear. Welcome to the club! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: new to the sportage world one question [Re: Sportege_Panicmech] #1010016 10/04/10 01:42 AM
DamKia Offline
Kia Moderator
We also have an entire thread devoted to tires and lifts at the top of this forum. Have a read through and ask away there.
Re: new to the sportage world one question [Re: DamKia] #1010017 10/04/10 02:02 AM
snowboardvdr Offline
im running general grabber at2 215/75/15. its a great tire, i love it here for our maine winters! i have a set of 225/75/15 at2 ready to go on. i have no lift. i found out i cant run spring spacers. not legal <img src="/forums/images/graemlins/frown.gif" alt="" /> i already have the tj springs and rav 4 shocks. still might do it tho.. hopefully they wont notice.. <img src="/forums/images/graemlins/smile.gif" alt="" />
if speed kill do brakes give life?
Re: new to the sportage world one question [Re: snowboardvdr] #1010018 10/04/10 12:22 PM
Dryver Offline
By "spring spacers", do they mean the type of spacer that actually threads in between the coils of the spring? Everet's spacers bolt to the top of the strut assembly. There is a difference.. Everet's might be legal for you.
01 Convertible; Electric Fan; 3" Up Your Kia lift spacers; Tj 104's; 31x10.5x15's on Centerlines; Rear LSD.
GONE, all I have left are a few spare parts and the wheels.
Re: new to the sportage world one question [Re: Dryver] #1010019 10/04/10 05:04 PM
Everet Offline
I have sold a couple of kits to guys in Maine. Biggest problem with them was rust!!
Spacer sits on top of the strut.
Hope that this info helps.
Re: new to the sportage world one question [Re: flaco] #1010020 10/05/10 02:44 PM
homerdog Offline
The 235/75/15's will rub on tight turns. Not sure what they rub on since I put my lift on shortly after I put the tires on. Didn't sound too serious though. <img src="/forums/images/graemlins/smile.gif" alt="" />
2001 Sportage, TJ 106's, Everet spacers and bumpstops, Bilstein shocks on the rear, cone filter, Crager wheels, 235-75-15 Goodyear tires. Custom front winch bumper by Dave Scott. Currently DOA, but it is a work in progress.
2011 Kia Forte EX
Re: new to the sportage world one question [Re: homerdog] #1010021 10/05/10 04:17 PM
Everet Offline
Check the underside of your front bumper. Most guys rub there and they just trim it away with a knife or dremel.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6411 MB (Peak: 0.7649 MB) Data Comp: Off Server Time: 2026-06-21 00:12:39 UTC
