22RE valve adjustment?? #1010088 10/04/10 12:35 AM
dave1223 Offline OP
Do most fellows with the 22RE adjust the valves at 8 and 12 hot,or are there any that do them 7 and 11 cold?
Re: 22RE valve adjustment?? [Re: dave1223] #1010089 10/04/10 03:12 AM
kewlynx Offline
I set them initially 8 and 12 with heavy drag. Warm up, check again and adjust if it's too loose for my liking.
This will also depend a tad on how worn the ends of your adjustment screws are, as they lose their convex surface over time.
**ubi apis- ibi salus**
Re: 22RE valve adjustment?? [Re: kewlynx] #1010090 10/06/10 03:20 AM
missouriman Offline
x2 on the screws.
usually they wear a half moon in them, so you go to adjust them and it steps up on the high part of the adjuster.
I took mine out, most of them were worn un even and used a stone to round the ends back out.
oh, you can tape the threads a bit and mount them in a drill at a slow speed and use the stone.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5921 MB (Peak: 0.6454 MB) Data Comp: Off Server Time: 2026-05-29 23:49:41 UTC
