It's a sickness (bought another one) #1010276 10/06/10 02:43 AM
sewerrat Offline OP
Found a 96 LS with a slipped timing belt. 136000 miles. One fender and hood don't match. Dirty as sin. The lot had a hack replace the fuel pump because it didn't start. The fool dropped the tank, trashed the level sender in the process. <img src="/forums/images/graemlins/shiner.gif" alt="" /> The look on his face made my day when I showed him the access plate. <img src="/forums/images/graemlins/smile.gif" alt="" />
I traded a Mazda mini van <img src="/forums/images/graemlins/barf.gif" alt="" /> and got $600 cash to boot. <img src="/forums/images/graemlins/kewl.gif" alt="" />
I also have a new job as a car lot mechanic if I want it. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> Which is good because my California job is dieing a slow death.
So here's one to all the sick, twisted freaks that share this illness we call Montero <img src="/forums/images/graemlins/cheers.gif" alt="" />
<img src="/forums/images/graemlins/rodent.gif" alt="" />
95 Montero SR 3.5 sitting on the sidelines.
96 Montero LS Daily driver.
88 Audi 90 Quattro marking it's territory.
69 Bronco built but uncut garage queen.
TANSTAAFL
Re: It's a sickness (bought another one) [Re: sewerrat] #1010277 10/06/10 02:47 AM
StockRaider Offline
<img src="/forums/images/graemlins/kewl.gif" alt="" /> gratz man <img src="/forums/images/graemlins/kewl.gif" alt="" />
If everything works out in the next few weeks I feel I may also get a 3rd mitsubishi <img src="/forums/images/graemlins/smile.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: It's a sickness (bought another one) [Re: StockRaider] #1010278 10/06/10 02:56 AM
You have lots of catching up to do, but welcome to the multi-Monty club!
Re: It's a sickness (bought another one) [Re: StockRaider] #1010279 10/06/10 03:30 AM
i"m trying for my third also.
Re: It's a sickness (bought another one) [Re: Mudraider] #1010280 10/06/10 07:50 AM
sewerrat Offline OP
I suppose it is cheaper than hanging around in bars, but not by much. <img src="/forums/images/graemlins/lol.gif" alt="" /> Way cheaper than the Bunny Ranch or illegally derived plant based substances.
Looking this thing over, I don't think it ever had any service done to it. $600 - $700 for parts depending on how many valves are bent. Everything I've found so far says it's an interference engine.
With the crank on the mark, the cams are 5 to 6 teeth off. I'm thinking that's not a good thing.
TANSTAAFL
Re: It's a sickness (bought another one) [Re: sewerrat] #1010281 10/06/10 05:59 PM
W
willwinchforfood Offline
Have you had a chance to retime the motor real fast and do a compression check? You may just get really lucky...
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
Re: It's a sickness (bought another one) [Re: willwinchforfood] #1010282 10/06/10 08:41 PM
<img src="/forums/images/graemlins/lol.gif" alt="" /> I thought I broke you of optimism...
It's an interference engine. Gates belts has a good web page for this.
Re: It's a sickness (bought another one) [Re: fasteddy] #1010283 10/06/10 09:23 PM
Monteros are hands down the best rig for the buck. The fact that they happen to be better than most rigs is a bonus. <img src="/forums/images/graemlins/mrt.gif" alt="" />
Congratulations on another great decision. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: It's a sickness (bought another one) [Re: sewerrat] #1010284 10/06/10 09:45 PM
<img src="/forums/images/graemlins/cyclops.gif" alt="" />
Re: It's a sickness (bought another one) [Re: off-roader] #1010285 10/06/10 11:56 PM
sewerrat Offline OP
Bent valves, no problem.
Crank bolt was loose, the sprocket key is damaged, crank sprocket beat on the crank snout. The crank sensor also got wiped out, trigger ring is toast. The threads seem OK.
I have a spare 3.5 sprocket but the trigger ring is different. The good sprocket is a bit loose w/o the key in place. Lock-Tite may save the day. Not in the mood to do a crank replacement. At least crank shafts for the 3.0 are cheap and plentiful compared to the 3.5.
Thinking the Bunny Ranch might be more fun right about now. <img src="/forums/images/graemlins/evil.gif" alt="" />
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/rodent.gif" alt="" />
TANSTAAFL
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6424 MB (Peak: 0.7663 MB) Data Comp: Off Server Time: 2026-06-10 01:57:42 UTC
