Replace or eliminate reed valve on exhaust manifold? - 2.6l #1010364 10/08/10 02:37 AM
sechack Offline OP
Just bought an almost perfect 88 Raider with 40k miles. The "hat" on top of the reed valve (secondary air into the air cleaner) is rusted out and resonating with the exhaust. Looks like it is a ~$200 part? Do I replace it new or used? Block it off somehow? Go with ~$200 headers? Any other suggestions?
Thanks
'88 Dodge Raider with only 52,000 miles!
My upgrades:
Curt 2" receiver tow hitch
Re-undercoated the wheel wells
Gen 2 padded center console cover "armrest"
Highland all-weather front mats
Double DIN JVC Receiver
Power locks with remote
Re: Replace or eliminate reed valve on exhaust manifold? - 2.6l [Re: sechack] #1010365 10/08/10 02:57 AM
cjsmontero Offline
I have an extra.......email me! Or Russell haha
85 Dodge D50, 90 Montero, 05 durango
Re: Replace or eliminate reed valve on exhaust manifold? - 2.6l [Re: cjsmontero] #1010366 10/08/10 03:36 AM
Or hacksaw off the pipe and block it with a quarter at the mani.
Re: Replace or eliminate reed valve on exhaust manifold? - 2.6l [Re: fasteddy] #1010367 10/08/10 07:50 PM
sechack Offline OP
OK, I think I will try the quarter trick for now till I find a replacement. Hopefully I will not have to cut the pipe though. It is brand new from the previous owner.
My upgrades:
Re: Replace or eliminate reed valve on exhaust manifold? - 2.6l [Re: sechack] #1010368 10/09/10 02:59 AM
May not cure the rattle, but it will block the exhaust flow, so you could maybe jam up the rattling part.
Re: Replace or eliminate reed valve on exhaust manifold? - 2.6l [Re: fasteddy] #1010369 10/09/10 02:01 PM
sechack Offline OP
Yep, put the quarter in there and it is still the same.
My upgrades:
Re: Replace or eliminate reed valve on exhaust manifold? - 2.6l [Re: sechack] #1010370 10/09/10 03:30 PM
zarktheshark Offline
so if you quarter doesn't fix the rattle, does that mean it isn't the read valve causing the problem?
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: Replace or eliminate reed valve on exhaust manifold? - 2.6l [Re: zarktheshark] #1010371 10/09/10 04:58 PM
Reed valve is a check valve to allow air flow only into the exhaust. The hat he has rattling is the vac valve that turns the system on and off, I think.
Re: Replace or eliminate reed valve on exhaust manifold? - 2.6l [Re: fasteddy] #1010372 10/10/10 01:49 AM
sechack Offline OP
Yep I need a "new" one or at least a good cap. Mine is rusted and almost completely off.
My upgrades:
Re: Replace or eliminate reed valve on exhaust manifold? - 2.6l [Re: sechack] #1010373 10/10/10 03:59 AM
cjsmontero Offline
Will blocking reed valve help with emissions?
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6420 MB (Peak: 0.7443 MB) Data Comp: Off Server Time: 2026-05-29 18:58:34 UTC
