Looking for a rebuilt AC compressor '88 2.6l Raider, mine is a different model.... #1010381 10/08/10 07:48 PM
sechack Offline OP
Ok, I have been searching here and on all the parts websites that say they have AC compressors for an '88 2.6l Raider. None of them match what is in mine. I have a DKS-15BH part number 509640-0304. Most of what I find and even had shipped to me end up having the ports on the top. Mine are on the back and mounting ears go front to back.
Any ideas?
Adding pictures...
'88 Dodge Raider with only 52,000 miles!
My upgrades:
Curt 2" receiver tow hitch
Re-undercoated the wheel wells
Gen 2 padded center console cover "armrest"
Highland all-weather front mats
Double DIN JVC Receiver
Power locks with remote
Re: Looking for a rebuilt AC compressor '88 2.6l Raider, mine is a different model.... [Re: sechack] #1010382 10/09/10 03:17 AM
Anyway you could post up some pictures of yours and the ones you have been getting? Maybe one of these guys with all the knowledge might be able to recognize what you have. It's an idea!
Re: Looking for a rebuilt AC compressor '88 2.6l Raider, mine is a different model.... [Re: Mudraider] #1010383 10/09/10 03:46 AM
A
airbats801 Offline
i just checked my 87. it has one port on the top going to tbe back and one port on the top going to the right side. Not sure on the part number though. sounds like you may need to look into a 87 pump?
8 Starion SHP, 87 mitsubishi van, , 81 galant g54bt, 78 lancer g54bt, 1965 Mitsubishi Debonair Deluxe
87 swb montero offroad pkg goin g54bt with sr locker 33x12.5 dual bouncy.
Re: Looking for a rebuilt AC compressor '88 2.6l Raider, mine is a different model.... [Re: Mudraider] #1010384 10/09/10 04:25 AM
sechack Offline OP
This is the one that I bought. Notice the ports on the top.
I will take picture of the one in the truck tomorrow.
My upgrades:
Re: Looking for a rebuilt AC compressor '88 2.6l Raider, mine is a different model.... [Re: sechack] #1010385 10/09/10 05:47 AM
DRaider90 Offline
My truck is an 88 and I just cut mine out in my alternator replacement adventure. Info on it:
FRONT:
NIPPONDENSO
047300-1960
12v 8G
BACK:
NipponDenso Co. LTD
6P148A 047200- 4990
DENSOOIL 6 76 0774
And on the side it has T 15 stamped on it. As far as where the ports are I guess that depends on what you call "the top". When mounted in the truck if I remember correctly the ports were on the side/bottom. If you set it down on the ground, the ports are on the top. They mounting eyelets are 2 front and 2 on the back, a lot different than that picture.
Don't know if this helps, but that is what I just took out of my truck.
88 Raider(Red):160k-Reman'd 2.6-5spd-Weber-SW Hubs-34x9.5 TSL-OffRd Pkg-1"Tbar-2"BL-CB
88 Raider(Silver):No 2.6/Bad KM145 Parts/Project
88 Montero(Brown):No 2.6,4.88s Parts/Project
[b]4X4 STICKERS,SHIRTS,ETC:
4WD Stickers AT COST.[b]
Re: Looking for a rebuilt AC compressor '88 2.6l Raider, mine is a different model.... [Re: sechack] #1010386 10/09/10 11:21 AM
P
pcc Offline
I don't know if this site will be of help but the owner is very knowledgeable and helpful and maybe can source or provide. I purchased shaft seal and gaskets from him to rebuild my Montero compressor.
http://www.acsource.com/
Re: Looking for a rebuilt AC compressor '88 2.6l Raider, mine is a different model.... [Re: pcc] #1010387 10/09/10 05:01 PM
I say it again, get yours rebuilt. It's a 6p type compressor, which is very common, and the internals should be readily rebuildable.
Re: Looking for a rebuilt AC compressor '88 2.6l Raider, mine is a different model.... [Re: fasteddy] #1010388 10/10/10 01:52 AM
sechack Offline OP
It seems to be frozen. Any suggestion on where to have it rebuilt or get parts to do it myself? Seems that AC site does not list this one other than gaskets and bearing/shaft seals.
My upgrades:
Re: Looking for a rebuilt AC compressor '88 2.6l Raider, mine is a different model.... [Re: sechack] #1010389 10/10/10 12:06 PM
P
pcc Offline
Phone him up:800-439-6695
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.6314 MB (Peak: 0.7352 MB) Data Comp: Off Server Time: 2026-11-19 23:56:27 UTC
