Re: Source for new Mitsubishi OEM Manual Locking Hubs
[Re: hazy_daze]
#1010468
11/09/10 04:07 AM
[quote]I'm guessing since this fits all the Gen II's on the list plus the 98 Gen II.5, Im assuming it works for the 99 & 2000 as well? I'm really not sure about the Gen II.5. I'd need a confirmation for somebody with one of these vehicles. My guess is NO they will not fit Gen II.5. Well, my guess is YES. Especially since everything has the same part numbers, ie flanges, bearings, etc... Photo or service manual page please. It's in ASA. The VIN's are available in the Tech Reference threads. It's so easy to use, I really don't understand why more folks don't use it to verify things like this. [/quote] Does ASA run on a Mac? I don't do windows.
- '83 Might Max: IG @83mmax
- '88 Raider: my OG
- '89 Raider: rescued
- '92 RS M/T: sold
- '93 SR: sent to crusher
- '05 Montero LTD: sold
- '18 PHEV: wife's daily
- '14 OL GT
- http://www.tuffpans.com
[Re: plh]
#1010469
11/09/10 04:47 AM
--keRby
Ad Inexplorta
[Re: 1986powerram50]
#1010470
11/09/10 05:27 AM
can't you run "Windows in a box" on a Mac?
[Re: plh]
#1010471
11/09/10 05:44 AM
I'm guessing since this fits all the Gen II's on the list plus the 98 Gen II.5, Im assuming it works for the 99 & 2000 as well? I'm really not sure about the Gen II.5. I'd need a confirmation for somebody with one of these vehicles. My guess is NO they will not fit Gen II.5. I'm with Larry, the Gen II.5 is the same across the board with all the SR's (atleast 94-97 SRs) just different gear ratio, but axle sizes and hubs should all fit the same. I was asking cause you had 98 on your site which is considered a Gen II.5 Either way, I'll def be saving up soon to get a set <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: fasteddy]
#1010472
11/09/10 05:51 AM
can't you run "Windows in a box" on a Mac? Not from what I recall. I looked into it a lot with caps wich is a .exe file, and you can't do it with that file type. I got frustrated with it and figured asa was the same maybe is/isn't. I'm sure it is tho 300D50 is a pal of mine and I run only macs and he was/is supplying bill with copies of ASA and caps. Tho he might have a suprise instore for me when I get my next box of goodies from hm..... he said he was whipping something up
--keRby
Ad Inexplorta
#1010473
11/09/10 07:38 AM
Yes the Gen 2.5 is still just a Gen 2, the only gen 2 that is a different truck is the evolution and it has more in common with the gen 3. hope that clears up some confusion.
[Re: fasteddy]
#1010474
11/09/10 12:25 PM
can't you run "Windows in a box" on a Mac? We use VMware Fusion to load Win XP Pro on my wife's MAC. All of the new MAC computers are pretty much a conventional PC now so the drivers used by each OS are fairly similar. She now does about 80% of her work in Windows but has some specific document production that needs the MAC.
[Re: OldColt]
#1010475
11/10/10 06:05 AM
If people can hold their feathers together, I'll see if I can get a fully slimmed down XP+ASA VM for VirtualBox whipped up. I can get an XP install down to ~ 400Mb, and ASA is mostly uncompressed TIFF images so ntfs compression should cut that down a bit. You'd be on your own ethics wise...
1989 Dodge Power Ram 50 w/ no engine <- rotten frame <img src="/forums/images/graemlins/frown.gif" alt="" /> 1988 Power Ram 50 2.6 Long Bed 1990 Mitsubishi MightyMax V6, swapping to the Daimler-Benz OM617 3.0L I5 diesel
[Re: 300D50]
#1010476
11/11/10 02:19 AM
If people can hold their feathers together, I'll see if I can get a fully slimmed down XP+ASA VM for VirtualBox whipped up. I can get an XP install down to ~ 400Mb, and ASA is mostly uncompressed TIFF images so ntfs compression should cut that down a bit. You'd be on your own ethics wise... Let me know about that. I run Virtual Box - not with windows today.
- '88 Raider: my OG
- '92 RS M/T: sold
- '14 OL GT
[Re: plh]
#1010477
12/01/10 01:04 AM
Beautiful! Especially considering that I blew out my hubs last weekend, this is perfect timing!
89 Raider V6 manual 89 Montero 2-door Coupe "Super Legera" 91 Montero 4-door manual (Mint! Sunroof, cruise, power everything, BOUGHT FROM THE ORIGINAL OWNER!)
