Montero rear disc backer plate, will it fit a V6 Mighty Max axle?
#1010696
10/12/10 08:32 PM
Got a question for all you monty guys.
Was just perusing ASA and it seems the Montero SR rear brake backers might have the same bolt pattern as V6 Mighty Max backer plates, and could possibly fit the Mighty Max axles.
So If anyone can get a few pics of the backing plates from an SR, or indeed any Montero with rear disc, preferably with bolt pattern info, I'd be stoked! <img src="/forums/images/graemlins/smile.gif" alt="" />
Would mean easy-peasy disc brake conversion for my truck, using factory parts! <img src="/forums/images/graemlins/kewl.gif" alt="" />
TIA
Walt
1989 Dodge Power Ram 50 w/ no engine <- rotten frame <img src="/forums/images/graemlins/frown.gif" alt="" /> 1988 Power Ram 50 2.6 Long Bed 1990 Mitsubishi MightyMax V6, swapping to the Daimler-Benz OM617 3.0L I5 diesel
Re: Montero rear disc backer plate, will it fit a V6 Mighty Max axle?
[Re: 300D50]
#1010697
12/19/10 08:38 AM
Bump.
It's been 2 months, still haven't found a montero to check this against, seems they're rare as hens teeth in the yards up here in the rust belt.
Any info greatly apreciated.
[Re: 300D50]
#1010698
12/19/10 04:12 PM
Bump.
Any info greatly apreciated. I've got a whole montero axle in storage ill have to check to see if they will fit on my truck.
95 Montero SR- Stock 90 Turbo Miata - TD04 wrx turbo, Flyin miata suspension, Torsen diff, 225 RS3's 92 Mighty Max 4x4 - Retired
[Re: hochkis]
#1010699
12/19/10 11:18 PM
Thanks! Be sure to let me know how it pans out!
[Re: 300D50]
#1010700
12/20/10 02:18 AM
Walt, I'll have the wheels off mine in the next week or so. I'll measure the bolt pattern and take a couple pics, if nobody beats me to it...
