Water inlet pipe puzzle #1010705 10/13/10 01:31 AM
red1987raider Offline OP
I can't find the right water pipe for my 4D56T engine. The engine is a '95 made by Hyundai for MItsubishi. I've dropped it into my '87 Dodge Raider with no problem, but finding the right pipe is a problem. I've included two images. The first one shows the pipe. The second shows the pipe laid out next to the thermostat housing. As you can see, the flared end of the pipe is much too large, and is angled the wrong way, to fit the recessed port on the housing, which is 23mm across. Can anyone help me out? Many thanks.
1987 Dodge Raider converted to 4D56T
Re: Water inlet pipe puzzle [Re: red1987raider] #1010706 10/26/10 05:02 AM
Jonno Offline
I have my waterpump out right now and the inlet pipe on mine only has one o-ring. I'm thinking either wrong pipe or thermostat housing,
Re: Water inlet pipe puzzle [Re: red1987raider] #1010707 10/28/10 08:09 PM
Mikewarme Offline
You have the older pipe and the newer water pump. The newer water pump has the additional housing. Is the turbo you are using water and oil cooled? Or is it just oil cooled. I happen to have a NEW Mitsubishi pipe for the housing you have with the angle. However, it does not have the tee junction for a water cooled turbo. If you can use it I want $40. It is new genuine Mitsubishi from Japan. Can't get it here in the states. Email me Mikewarme@yahoo.com
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.005s) Memory: 0.5927 MB (Peak: 0.6463 MB) Data Comp: Off Server Time: 2026-10-21 17:45:53 UTC
