Plastic timing chain guides,mileage expectancy? #1010776 10/13/10 12:59 PM
dave1223 Offline OP
The P/O put in a new timing gear kit but used the one with plastic guides..three months ago.Will this last 80-100 thousand miles,or less?
Re: Plastic timing chain guides,mileage expectancy? [Re: dave1223] #1010777 10/13/10 02:33 PM
Martini Offline
With my 290,000 mile 86' 22RE Runner, I had to do the chain 3 times. This last time I upgraded to the LC dual chain kit with the steel guides, so thats about 96K with the plastics. By the way, if some you remember back awhile I had some problems with excessive noise after the install. Turns out, my idler pulley bearing was shot, which sounded like my engine was coming apart! Fixed.
86' 4Runner, Manual 22RE, Grey SR5
05' 4Runner 4WD Sport, Silver
Re: Plastic timing chain guides,mileage expectancy? [Re: dave1223] #1010778 10/13/10 03:52 PM
stock87 Offline
I think it depends a lot on driving style. My '87 which always sees every regular maintenance, had the first set (from the factory) break at 175,000 miles. The factory recommends replacement every 100,000 I think, so 1.75 times the factory interval sounds pretty good to me.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: Plastic timing chain guides,mileage expectancy? [Re: dave1223] #1010779 10/19/10 10:30 PM
engnbldr Offline
>>>*We see them come in consistantly broken at around 125,000 miles, some last far longer though. Rarely far less, in those cases the engine is having a bit of a rough life. Those that seem to last forever are almost always highway vehicles driven long distances daily.
It isn't the guide that is the problem though, it is the tensioner nearly without fail. Once it begins to leak down, the guide isn't long for the world....*EB
*Beats the he** outa me!....*LOL**...
Re: Plastic timing chain guides,mileage expectancy? [Re: engnbldr] #1010780 10/19/10 11:51 PM
dave1223 Offline OP
Thanks fellows.....
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6063 MB (Peak: 0.6715 MB) Data Comp: Off Server Time: 2026-06-10 06:34:08 UTC
