Front solid axle conversion #1010833 10/13/10 07:42 PM
G
GettinShacked Offline OP
wanted to know what kind of axle anyone has used like off of what or some kind of dana axle. I know there is no bolt on solution and i dont mind starting from scratch, welding, fabbing, and planning just want to know if theres a certain axle to use
Re: Front solid axle conversion [Re: GettinShacked] #1010834 10/14/10 12:16 AM
DEFBOY35 Offline
do a search on here. you will find a few posts with some good info.
but off the top of my head rokia used a 85 era toyota solid axle, and dave scott used a dana 44 from a old scout i think, might be wrong on that one. but should find for sure in a post on here somewhere. basically any passenger drop axle should work for you, well depends if you care about bolt pattern or not.
i personally went with a custom housing.
good luck. i am hoping to get back at my swap this winter and have her ready for some wheeling next spring.
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5900 MB (Peak: 0.6379 MB) Data Comp: Off Server Time: 2026-05-29 17:26:02 UTC
