Stumbling in top gears. #1011122 10/16/10 09:35 PM
F
fido1 Offline OP
87 SWB 2.6l 5 speed. Runs great in first through third. Fourth it starts lacking for power at 2800 rpm WOT. Fifth has little power and is almost impossible to hit 2800 rpm. In fifth it will start top pop like a backfire into the carb. New cap, rotor, plugs, fuel filter is good, and pump seems to fill the filter fast. Any ideas?
Re: Stumbling in top gears. [Re: fido1] #1011123 10/16/10 09:58 PM
mxmikie Offline
plug wires
Re: Stumbling in top gears. [Re: mxmikie] #1011124 10/17/10 01:51 AM
Check your timing, too. Wires helped out my Raider most, though, with the same issues.
Re: Stumbling in top gears. [Re: fido1] #1011125 10/17/10 02:05 AM
F
fido1 Offline OP
Thank you guys I'll change them in the morning.
Re: Stumbling in top gears. [Re: fido1] #1011126 10/17/10 02:06 PM
plh Offline
Secondary diaphragm in the Mikuni would be the thing to check after plug wires. Sounds to me like its leaking.
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Stumbling in top gears. [Re: plh] #1011127 10/27/10 05:59 AM
F
fido1 Offline OP
HA HA Changed the wires..nothing, Changed the coil..nothing. Checked timing.. prefect. Changed the fuel filter..same problem. Checked the Air cleaner, Hey, whats that hole in the rubber seal??? Replaced and all is well again.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6084 MB (Peak: 0.6775 MB) Data Comp: Off Server Time: 2026-06-07 07:22:32 UTC
