Installing hitch and wiring for towing
#1011167
10/17/10 11:31 PM
Lookin' for a pickup or 4runner. My question is: When there is not a hitch or wiring (4-wire flat) already installed, do these frames come from the factory pre-drilled (holes) where a hitch would bolt up, or does a person have to make your own holes? I suppose they're pre-drilled, but I dunno.
Also, what is involved in wiring up a 4-wire flat harness?
Re: Installing hitch and wiring for towing
[Re: outdoorfan]
#1011168
10/17/10 11:38 PM
I think the trucks are rated to two 3,500 lb. A class II hitch will bolt into existing frame holes. You will need a 'converter' box to run a flat-4 trailer connector since it has combined run/brake lights, which the truck do not. Just splice into the existing light wires. A wiring diagram is a big help here. Figure $150 for a Class II hitch and $50 for wiring and the box if you install yourself.
1989 4Runner Special Edition 22RE, 5-spd. TG 3" SAS, MC DuaLs, 4.56s, Air Locker Hi-Clearance panels by www.toyotafiberglass.com
[Re: Pyroboy]
#1011169
10/18/10 01:08 AM
Thanks. Sounds easy enough.
[Re: outdoorfan]
#1011170
10/19/10 12:51 AM
I have a class 3 on mine, got it from JC Whitney I think. Bolts right up (have to remove the bumper, then bolt it and the bumper together in the same holes).
Todd
1986 Pickup extracab longbed "Woody edition" SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD" 94 2wd v6 extracab 04 Outback Wagon- wife's/family car
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6023 MB (Peak: 0.6577 MB) Data Comp: Off Server Time: 2026-11-03 13:36:35 UTCValid HTML 5 and Valid CSS
