Brazing broken front sway disconnect #1011204 10/18/10 07:08 AM
bretwalda Offline OP
I've got one of the original prototypes of Misterbishi's front sway disconnects on my ride (Augie's old ride circa 2003). Unless someone knows otherwise I don't think his new one is available anymore.
I believe the threaded pins that locked the halved bar to the pivoting disconnect piece are rusted or worn which is giving me a pop when I corner.
I really like this mod and would like to keep it but chances are retooling it is not an option.
At the welding supply I saw some brazing wire that is 45% silver - I believe it was these guys...I dont remember what the disconnect was made of but it looks like some sort of chromoly. Do you think brazing with this silver stuff around the whole outer edge of the two ends (where the bar fits into the disconnect) would be enough to hold it on there or am I wasting my time & $$?
concreteprinter.com
Re: Brazing broken front sway disconnect [Re: bretwalda] #1011205 10/18/10 07:14 AM
FWIW here's a pic I found of my bar:
concreteprinter.com
Re: Brazing broken front sway disconnect [Re: bretwalda] #1011206 10/18/10 04:19 PM
I would weld it being careful not to get it too hot. Get on it quick and do short little beads then cool it down with a splash of water.......repeat <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Brazing broken front sway disconnect [Re: bretwalda] #1011207 10/19/10 01:25 AM
DamKia Offline
Kia Moderator
Brazing it will not be strong enough. It is basically high temp soldering with no metal penetration of the two surfaces to lock them together.
Re: Brazing broken front sway disconnect [Re: DamKia] #1011208 10/19/10 02:11 AM
Mad_Scientist Offline
I would think welding a sway bar would be a bad idea. Can the old set screws be drilled out, the holes re-threaded and new screws inserted?
Those disconnects are cool <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Brazing broken front sway disconnect [Re: Mad_Scientist] #1011209 10/19/10 02:20 AM
Welding a sway bar IS a bad idea....but I think it can be done with short bursts and cooling it down right away.
Set screws are probably a better idea. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Brazing broken front sway disconnect [Re: cmonty72] #1011210 10/19/10 05:56 PM
hazy_daze Offline
What are these sway bars you speak of?
Re: Brazing broken front sway disconnect [Re: hazy_daze] #1011211 10/20/10 05:19 AM
52degrees Offline
I think those are those metal bits I took off and threw away years ago. Lol.
KG6VNX
Re: Brazing broken front sway disconnect [Re: 52degrees] #1011212 10/20/10 11:59 PM
Yes, ride with Hazy thru curves at speed and watch our combined massive body weight peg the tiltometer...
I like the disco's - best of both worlds.
Re: Brazing broken front sway disconnect [Re: fasteddy] #1011213 10/21/10 05:10 PM
hazy_daze Offline
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> I've learned to slow down.
And I've lost a little weight.
And I don't have a tiltometer anymore.
Thank you very much...
If I had reliable disco's, I'd run swaybars in the front...
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6429 MB (Peak: 0.7658 MB) Data Comp: Off Server Time: 2026-10-22 07:41:11 UTC
