skid plates
#1011449
10/22/10 04:23 AM
Is there anyone out there that makes skid plates for my 87 ram 50. I am looking for one for the gas tank and a better one for my oil pan
1987 Dodge Ram 50 2.6 5 speed 2 inch body lift 31x11.50 Swamper LTBs 4.62 gears lsd rear and welded front with lockouts Weber carb waiting to be installed
Re: skid plates
[Re: Red1979]
#1011450
10/22/10 05:54 PM
Nope. <img src="/forums/images/graemlins/frown.gif" alt="" /> Reinforce yours or if they're already trashed, find a good set in a pick n pull and reinforce them to your needs. Don't forget to also reinforce the mount points on the frame. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: skid plates
[Re: Red1979]
#1011451
10/22/10 06:33 PM
The 4wd trucks had them but may not be a direct fit. The gen1 truck had a different frame than the 2wd, iirc.
Re: skid plates
[Re: fasteddy]
#1011452
10/22/10 08:33 PM
The 4wd trucks had them but may not be a direct fit. The gen1 truck had a different frame than the 2wd, iirc. I think his is a 4wd truck cause in his sig he mentions the front's are locked/welded.
Re: skid plates
[Re: off-roader]
#1011453
10/22/10 10:46 PM
Yeah I got an 87 pickup. It has the front plate but doesn't cover the oil pan. It doesn't have anything to cover the gas tank. I moved the gas tank up about 4 inches....I don't think I would have trouble with the one to cover the oil pan but the gas tank would be tricky
Re: skid plates
[Re: Red1979]
#1011454
10/22/10 11:15 PM
My 85 4wd d50 needed a tank skid plate. Lots of banging going on with that long overhang "long bed". I always wanted to flatbed that truck and relocate a custom tank ahead of the rear axle, maybe up to the bottom of the flatbed which would be at top of frame arch at the rear axle. The pickup has a really good approach angle stock, and with a bobbed rear end, to no more than a foot behind the rear wheel, it ought to slop around really well.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6108 MB (Peak: 0.6812 MB) Data Comp: Off Server Time: 2026-06-22 10:09:52 UTCValid HTML 5 and Valid CSS
