Rear end Started knocking today????
#1011737
10/26/10 04:00 AM
Just driving along today and started to hear a knocking sound so I pulled over to a buddies house and checked it out to see where it was coming from and the rear axle had a little bit of fluid around the pinon seal. So I started to go back and forth in his drive way and the axle would knock at a certain stop and feel like my truck was boucing slitly. And about a year ago I had a pinon seal leak on my rear axle and fixed it. So if any body had some addice on where I should start or what the problem is I'd apperciate it before I start taking it apart. And does the sound mean the gears are done for??
95 4runner 35x12.50 w stock 4.56 Going to go ahead and get the 5.29's if the gears are F'ed up.So help!!
Re: Rear end Started knocking today????
[Re: 4runTAZ]
#1011738
10/26/10 11:25 AM
I would take a look at the U-joints. Sounds more likely than something in the rear diff.
Hand me that crowbar.
[Re: krauthead]
#1011739
10/26/10 01:24 PM
See if you can determine what frequency the clunking noise is at. If it happens once per wheel revolution, then it is likely a ring gear issue. If it happens once per drive shaft rev, then it may be u-joint or pinion gear related.
I had a similar issue in my VW and finally determined it was a once-per-wheel-rev clunk and as it turned out it was a bad ring gear in the transaxle.
[Re: 4Crawler]
#1011740
10/27/10 11:39 PM
well i took my drive shaft off and spun my back tires and it seemed ok. Then i spun the circle part the drive shaft connected to and it was locking up. any thoughts?
[Re: 4runTAZ]
#1011741
10/28/10 02:43 AM
Sounds like it's time to open it up if the pinion flange isn't moving. I take it that's the round part you're referring to?
[Re: 4runTAZ]
#1011742
10/29/10 04:52 AM
yea it is. I never thought how hard it is to take off drum brakes . dAMN
[Re: 4runTAZ]
#1011743
10/29/10 05:33 AM
Using two little bolts to back the drum off is key.
[Re: kewlynx]
#1011744
10/29/10 05:42 AM
Using two little bolts to back the drum off is key. And...if the shoes are set snug with the drum (like I have mine) the "two bolt trick" won't separate the two without first manually backing off the shoes through that little access hole in the back.
[Re: 4runTAZ]
#1011745
10/31/10 01:53 AM
Got it all taking apart and got the brakes redone now just have to get some 5.29's and itll all be done. My gears where broke and have a few metal pices in the axle. Any advice when im putting the 3rd member back in?/? and wheres a good place I can get a complete setup to pop back in before I get one off of marlin crawler.com
[Re: 4runTAZ]
#1011746
10/31/10 07:50 PM
did you try the for sale section here on the wire? I'd also poke around your local craigslist and fleabay.
always working
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6362 MB (Peak: 0.7589 MB) Data Comp: Off Server Time: 2026-05-29 16:15:34 UTCValid HTML 5 and Valid CSS
