'95 4runner brake problem stiff pedal
#1011949
10/29/10 10:16 PM
the pedal is stiff but truck doesn't want to stop unless i press the brake pedal really hard. the front pads are new. performed the booster test and air tightness test and when i start the engine after pumping and holding the pedal down, it actually raises a little. I tried trouble shooting according to the factory service manual, but couldn't figure it out. any ideas?
'95 runner 3vze/r150f
Re: '95 4runner brake problem stiff pedal
[Re: gueroblanco]
#1011950
10/30/10 05:50 PM
Contaminated brake fluid is a possibility. Did you do a visual check on the hard lines to make sure they aren't pinched?
always working
[Re: Macka]
#1011951
10/31/10 03:49 PM
yes checked and bled the lines yesterday. also inspected the rear brake adjustment. the fluid wasn't the worst I've seen and the rear brakes seemed good.
seems to me that it has got to be a bad booster? when i press the pedal it doesn't 'pump up' like it used to. when i pump several times, hold down the pedal and start the engine there is no change in pedal height.
the booster pushrod couldn't get out of adjustment could it?
[Re: gueroblanco]
#1011952
10/31/10 03:52 PM
probably less headache to swap out the brake booster then play with the adjustment
always working
[Re: Macka]
#1011953
10/31/10 05:22 PM
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6056 MB (Peak: 0.6698 MB) Data Comp: Off Server Time: 2026-06-17 13:25:47 UTCValid HTML 5 and Valid CSS
