Does removing the oil filler cap, engine idle's almost off, say bad HG? #1012205 11/03/10 05:50 PM
StevieTees Offline OP
95 3.0 running real bad, took it to the dealer and he said there was water in the oil, but you cannot see it? But when you loosen & remove the Oil filler cap it will kill the engine. HG going bad?
Re: Does removing the oil filler cap, engine idle's almost off, say bad HG? [Re: StevieTees] #1012206 11/03/10 08:23 PM
Ralph Offline
Milky looking oil is water in the oil.
Everything else is everything else.
Ralph
1991 Toyota 4x4 Standard Cab Pickup.
engnbldr cam and head.
Doug Thorley Headers
Home Made Cat Backs
30x9.5x15 BF Goodrich All-Terrain M/T KM2
Re: Does removing the oil filler cap, engine idle's almost off, say bad HG? [Re: StevieTees] #1012207 11/04/10 03:56 AM
missouriman Offline
no, removing the oil fill cap kills the vacuum.
the Positive Crankcase Ventilation.
is your oil milky looking?
you can also pick up a kit to test your coolant for exhaust gases.
Re: Does removing the oil filler cap, engine idle's almost off, say bad HG? [Re: StevieTees] #1012208 11/11/10 07:00 PM
O
outdoorfan Offline
In the two HG's that my 22re has blown, the bottom side of the oil filler cap had a milky substance stuck to it. Check that, and that NAPA chemical test kit works great.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6004 MB (Peak: 0.6555 MB) Data Comp: Off Server Time: 2026-05-28 01:03:20 UTC
