Low beam not working
#1012308
11/05/10 02:41 AM
Hey guys... just put my lights back in, for a few minutes the driver side headlamp worked fine, now only the high beam works. I switched with new bulbs and still the same thing... only highbeam. Passenger side works fine. What could cause this?
89 4Runner 3" BL, M/T locks, 33"bfg mt, bilstein, Kayline, tubebumper, toyotafiberglass panels TBI: Elocker,3.4 w/ORS,b+b,S2Sstg2cams,arias pistons,P+P intake,TRDs/c,URDpullies+7th,downey headers,MAPECU2,WEGO WB, SupraMAF,walboro255,stg4clutch, EPaOo2 sim
Re: Low beam not working
[Re: 4Crawler]
#1012310
11/05/10 06:48 PM
I checked the voltages they look good. I was having a problem finding a good ground when in low beam however....?
[Re: Greg_Canada]
#1012311
11/06/10 01:03 AM
I checked the voltages they look good. I was having a problem finding a good ground when in low beam however....? Well the head lights are switched ground, meaning the low beam terminal has a ground switched via the column dimmer (combo) switch. So if you do not see close to 0 volts at that terminal in low beam mode, that is your problem. In this case, 0 volts = good, 12 volts (or anything over 0.5 volts) = bad.
[Re: 4Crawler]
#1012312
11/11/10 02:43 PM
the wire corroded off where it clamps the plug, but didn't pull out because the wire wrap holder still held it in. Pulled it all apart and soldered it back together, works like new.
[Re: Greg_Canada]
#1012313
11/19/10 12:01 AM
I know you fixed it, but also there is a fuse for each headlight. I ran across this myself.
[Re: Adam F]
#1012314
11/19/10 04:10 PM
I know you fixed it, but also there is a fuse for each headlight. I ran across this myself. Yup, popped those last year in the winter (oops?) then neither hi or low will work. If it's either high or low not working... check the plugs! Cheers, Greg
[Re: Greg_Canada]
#1012315
11/24/10 03:20 AM
Mine was weird....the headlight worked but was VERY dim...swapped it out and still dim. Replaced the blown fuse and all was good.
[Re: Adam F]
#1012316
11/24/10 02:58 PM
That's really weird... almost like the fuse still had a slight connection....
