Page 1 of 3 1 2 3
Think i found the problem pic in post .. help needed #1012389 11/07/10 02:19 AM
leftnutt35 Offline OP
ok as was changing the oil today and looking around i found a vacuum nipple behind the the throttle body or plenum with no line on it at all. problem is i don't know where it goes. has a bunch of vacuum behind. it looks like it goes no where under the hood maybe tranny ? i plunged it off for now seemed to idle better the whole motor is alot smoother and no more bucking up a hill. now pic is not the best took it with my phone and had a mirror on it so i could see it to take the pic. any one got any ideas. [Linked Image]
95 SR stock but i hope not for long....
Re: Think i found the problem pic in post .. help needed [Re: leftnutt35] #1012390 11/07/10 02:51 AM
Why'd you start a whole new thread and then delete the one with all your symptoms?!? <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Think i found the problem pic in post .. help needed [Re: off-roader] #1012391 11/07/10 02:54 AM
because i am dumb <img src="/forums/images/graemlins/smile.gif" alt="" /> i have been having trouble with it bucking when going up hills . had it scanned no codes. been pulling my hair out over this for like 2 weeks. just seemed like a new thread was the way to go.. I am sorry if i upset anyone.
Re: Think i found the problem pic in post .. help needed [Re: leftnutt35] #1012392 11/07/10 02:59 AM
Not upset... But for future reference, since this is all one issue/problem keeping it in one thread is better IMHO. Future readers can see the evolution of the problem from beginning to end. More helpful that way, you know what I mean?
That said, I hope this is the source of the weird running.
Re: Think i found the problem pic in post .. help needed [Re: leftnutt35] #1012393 11/07/10 03:59 AM
87Montero Offline
It's been a minute since I tore all that down several times. If I recall though, isn't' there a vacuum hose routing under the hood somewhere?
Re: Think i found the problem pic in post .. help needed [Re: 87Montero] #1012394 11/07/10 04:46 AM
if there is its long gone..
Re: Think i found the problem pic in post .. help needed [Re: leftnutt35] #1012395 11/07/10 10:58 AM
P
pcc Offline
Not sure what I'm looking at - is that the firewall behind the vac line connection and is that the EGR line next to it? My only reference is 1992 Model but could be charcoal canister, fuel pressure regulator line or EGR control solenoid.
Re: Think i found the problem pic in post .. help needed [Re: pcc] #1012396 11/07/10 05:55 PM
yes it is the fire wall ect... i not sure what it goes to yet. but runs alot better so far. with it just plugged been going through the lines under the hood replacing them so far i don't see where it goes.
Re: Think i found the problem pic in post .. help needed [Re: leftnutt35] #1012397 11/08/10 12:51 AM
Is it full or ported vac? I mean, is there vac at idle and at higher engine speeds, or just at above idle? Originally, fuel pressure regulator had a blue stripe hose, intake changeover hose had a black stripe, egr is green, and evap purge solenoid is red stripe.
Re: Think i found the problem pic in post .. help needed [Re: fasteddy] #1012398 11/08/10 06:57 AM
I only tested it at idle and i but some gas on it and it pressure also. I now with it plugged my bucking problem at hills ect is gone. idles smoother just all around smoother all together.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6416 MB (Peak: 0.7658 MB) Data Comp: Off Server Time: 2026-05-29 19:53:16 UTC
