Coolant leak is back.
#1012414
11/07/10 04:08 AM
Don't know if I posted about this earlier, but I had a pretty bad coolant leak last winter. Had 2 leaks in the rad and a bad thermostat gasket. All those issues were fixed, but I have a slow drip under the truck again!
Just ranting, hope the weather is nice enough tomorrow to have a look.
Re: Coolant leak is back.
[Re: redbull]
#1012415
11/08/10 05:28 PM
Sorry to hear that!
Did you use chemicals to stop leaking last time?
The best way to fix it is to change leaking parts I guess...
Fight for Right to drive from Right! www.ivoac.caStay away from Nic's Garage at 120 West 1st Ave in Vancouver BC!!!
[Re: Pajerist]
#1012416
11/08/10 07:53 PM
No, I had the rad re-cored and cut a new gasket. Gotta get under the truck to see where the leak is, but all the stuff in the way makes it hard to see!
[Re: redbull]
#1012417
11/10/10 08:02 AM
my little o-ring that goes from the water pump to water pipe had a slow leak for over a year before i found it. just something the check! mine wasn't even a year old from when i did the timing belt and it started leaking.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6028 MB (Peak: 0.6581 MB) Data Comp: Off Server Time: 2026-10-21 22:06:50 UTCValid HTML 5 and Valid CSS
