if you are running an aftermarket head(s), check in here #1012518 11/08/10 05:36 PM
builthatch Offline OP
i'm considering a loaded clearwater head for my 2.6L. i'm mainly concerned about who is running that, but anything else will probably be good info for other users coming down the pike.
i've seen a few people who have issues with clearwater heads, but then i've seen other who don't. i guess with anything that is somewhat popular, there are detractors or issues. i'm not sure. i do know that i am not anxious to spend much more than 400 bucks for a loaded head and machining to get my stuff to work on a bare head will make it all about the same cost.
'87 swb 5spd 2.6L Montero, >150k miles. Pretty much bone stock as purchased from user ToddStidham1, 'cept some Hella 500's, 700's and Hella ECE headlight conversions.
6'4", 315lbs
Re: if you are running an aftermarket head(s), check in here [Re: builthatch] #1012519 11/10/10 04:31 PM
cdl1701 Offline
I have been running a clearwater for over a year now with no issues at all.
88 Montero, 2.6 Black
Re: if you are running an aftermarket head(s), check in here [Re: cdl1701] #1012520 11/10/10 06:28 PM
I've run Clearwater heads on my 2.6's, starting maybe 7-8 years ago and have never had an issue with them.
Re: if you are running an aftermarket head(s), check in here [Re: builthatch] #1012521 11/10/10 06:40 PM
Just a thought but you might get more response if you titled your post more accurately/precisely such as "Opinions of Clearwater heads wanted from users".
Re: if you are running an aftermarket head(s), check in here [Re: JohnnyBfromPeoria] #1012522 11/10/10 07:03 PM
zarktheshark Offline
I'm running one with no issues. Bottom line, IMO, is that any head that does NOT have the jet valves is going to be better than a stock head.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: if you are running an aftermarket head(s), check in here [Re: zarktheshark] #1012523 11/10/10 11:38 PM
A
airbats801 Offline
I've never had issues ith the jetvalves, They always crack in between the valves.Even a njv caravan head is just as prone to cracking as the oem heads.
It comes down to either you want to pony up the money for a manral or magna head or you dont.
I had a rare marnal jet valve head, overheated it sooooo many times. We are talking pegged while drifting my old drift beater, and never bhg or cracked a head and it had a 18g on it.
8 Starion SHP, 87 mitsubishi van, , 81 galant g54bt, 78 lancer g54bt, 1965 Mitsubishi Debonair Deluxe
87 swb montero offroad pkg goin g54bt with sr locker 33x12.5 dual bouncy.
Re: if you are running an aftermarket head(s), check in here [Re: off-roader] #1012524 11/11/10 04:17 AM
i'm interested in opinions on any aftermarket heads. alabama, the cheap castings from the starquest dude in Ohio, Randy, etc.
i'd love to get a marnal head but i can't justify a head that costs about what the truck originally cost me ; )
6'4", 315lbs
Re: if you are running an aftermarket head(s), check in here [Re: builthatch] #1012525 11/11/10 05:53 AM
that could have been your post title right there... Maybe event put 'help' in front of it.
Doing it this way also helps when someones searching for it in the future. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: if you are running an aftermarket head(s), check in here [Re: builthatch] #1012526 11/12/10 06:40 PM
djacidjac Offline
I am in the midst of installing a clearwater head. I got it with valves only. not sure if there's a cost difference. would've gotten it complete. miscommunication i guess. anyway, the 4th intake valve is mysteriously leaking. it's back at clearwater now with my old rockers/cam/etc. I think it's just a fluke. Their head itself I think is fine, to answer your question directly. They suggested maybe a delivery accident on the valve. Also, their website does not work on my computer. I had to order by phone. I chalk up my negative experience to bad luck. They seem professional with a good product. They offer the least expensive new casting I could find. I'll update once I get the final head installed and running. If I had to do it again, I'd get a bare Marnal (I may have a local source, he used to be a dealer) and have the shop swap over the stuff. It would've cost me only about $100 more at this point, and less time. But if it goes in right the first time, clearwater is the way to go.
EDIT
I'd go new casting because I'm afraid of metal fatigue on a used head. also, no jet valve ports.(although my head cracked between the valves on each #2 and #3, not at the jet valves.)
IMHO, I'd go Marnal if the engine will be built up (turbo or whatever) and/or run very very hard /abused.
maybe more info here:
http://www.4x4wire.com/forums/showthread...&PHPSESSID=
87 Dodge Raider 5sp 2.6l no jet valves, Tuffpan
OME Dakar leaf springs + T-bar crank + 2" body lift (4" lift).
5500lb winch, Starion alternator, grp31 marine bat'
OBA (stock AC compressor)
33x12.5x15 Baja Claws or Wintermark extra load 235/75/15 M/S
Re: if you are running an aftermarket head(s), check in here [Re: djacidjac] #1012527 11/13/10 04:39 AM
sasnydley Offline
I live an hour from there! I put New casting heads on my 3.0 a couple yrs ago. Done 240k. Now has 266K-Thats running 33's all that time so probably closer to 270ish... no problems whatsoever- went to the shop to buy them.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6378 MB (Peak: 0.7485 MB) Data Comp: Off Server Time: 2026-06-07 07:24:22 UTC
