Re: How to replace your ignition switch (96SR Montero)
[Re: ryany]
#1012885
11/18/10 09:06 PM
That's true & a good point. Someone mentioned that to me also when I was looking for a fix. Here was my thinking... 1) My monty has >230k miles. 2) Switch was $40. 3) Replacing the switch was very simple to do. Knowing what I know now, I'm sure I could do it in <10 min. 4) Either the switch or the relay could fail, as could any of the new wires/connectors I'd have to add if I did this mod. Would it last as long as the stock switch which is easy to replace? Is it a worthwhile mod? In my case, I elected to go with just a new switch.
I felt replacing the switch was the path of least resistance and the simpler solution but YMMV & that's why I posted my train of thought... <img src="/forums/images/graemlins/cyclops.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: off-roader]
#1012886
04/04/13 12:42 AM
Thanks a ton for this write-up...even with the dead picture links the description gave me enough to go on and I replaced mine in about 20 minutes....cheers! <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.5944 MB (Peak: 0.6591 MB) Data Comp: Off Server Time: 2026-11-02 04:02:07 UTCValid HTML 5 and Valid CSS
