axle breathers #1012988 11/15/10 01:44 AM
Tag Offline OP
Long time ago I saw a product that you hooked to your axle breather outlet for just about any axle and instead of a tube it was just a piece of plastic that expanded and contracted with the air. Anyone know where to find them?
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: axle breathers [Re: Tag] #1012989 11/15/10 02:00 AM
4x4Wire Offline
K&N does (or did) have a small filter that had a fitting to connect to a rubber tube. Haven't looked into it for about 15 years.
Not sure if that is what you are looking for...
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: axle breathers [Re: Tag] #1012990 11/15/10 02:55 AM
Kevin C Offline
Sounds like a bellow that changes volume. Never seen one for axles, but I'm familiar with the concept.
Re: axle breathers [Re: Kevin C] #1012991 11/15/10 04:24 AM
Tag Offline OP
yep that is a good term for it. I have seen them but had no interest in them at the time.
Re: axle breathers [Re: Tag] #1012992 11/15/10 04:51 AM
redbull Offline
Re: axle breathers [Re: Tag] #1012993 11/15/10 01:57 PM
lee_raider Offline
I've seen balloons used quite often.
Two MRI's and a CAT scan....it's confirmed. I'm just not right in the head.
Re: axle breathers [Re: lee_raider] #1012994 11/15/10 04:17 PM
G
Greg_Canada Offline
89 4Runner
Re: axle breathers [Re: Greg_Canada] #1012995 11/15/10 06:44 PM
You'll probably want to check the clearance during full compression on either side and ensure this doesn't get compressed once it's mounted.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6248 MB (Peak: 0.7222 MB) Data Comp: Off Server Time: 2026-11-02 21:46:38 UTC
