Page 1 of 3 1 2 3
Replace Rod Bearings #1013102 11/16/10 06:48 PM
89montero Offline OP
Well I spun a bearing a couple weeks ago, making a pretty bad knock but I think it still might be salvageable.
Today I'm going to pull the oil pan and see if I can get away with just putting new bearings in.
Only thing, how can I tell if the bearings that are in there now are stock or over sized? The PO had the motor rebuilt at a Mitsubishi dealer, probably about 10 years ago. Would they have used over sized bearings?
Thanks
1989 Montero 4dr V6 3.0l
Re: Replace Rod Bearings [Re: 89montero] #1013103 11/16/10 08:39 PM
hazy_daze Offline
It's usually stamped into the bearing. Most likely, unless there was a catastrophic failure, standard bearings would have been used.
Re: Replace Rod Bearings [Re: hazy_daze] #1013104 11/16/10 09:03 PM
Randy_NC Offline
I was about to post a similar question. With 160k on my 1989 V6 should i replace the bearings before I have an issue. How difficult is this job.
Re: Replace Rod Bearings [Re: Randy_NC] #1013105 11/16/10 09:28 PM
hazy_daze Offline
Unless you're having an issue, no. Don't fix what ain't broke. If you're curious about the internal condition, have your oil analyzed at Blackstone.
Re: Replace Rod Bearings [Re: hazy_daze] #1013106 11/17/10 02:46 AM
MBrannon Offline
You'll get about 1000 miles out of the new bearings before they knock again.
I'm a big fan of replacing the rod bearings and oil pump as preventative maintenance on the 6G72.
1992 VR4 12.5 @ 110 - SOLD
1993 Stealth RT/TT 11.4 @ 129 - SOLD
1991 VR4 9.2 @ 159 - Old Shop Car
1992 Stealth Twin Turbo ATX - SOLD
1990 Montero LS LWB - RIP
1995 Montero LS - RIP
1998 Montero
1992 Galant VR4 474/1000
2007 Prius
Re: Replace Rod Bearings [Re: MBrannon] #1013107 11/17/10 03:29 AM
sewerrat Offline
IMHO, if there are any problems with the crank, replacing the bearings will be a temporary fix at best. These engines are incredibly durable. They are also quite intolerant to any problems on the bottom end. They just don't respond well to being patched together. There is a reason the "re-manufactured" engines have a poor reputation.
I'm not saying you don't have the skills to pull this off, or may get lucky. For myself, I would feel better spending the cash at the local Indian casino. <img src="/forums/images/graemlins/lol.gif" alt="" />
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/rodent.gif" alt="" />
95 Montero SR 3.5 sitting on the sidelines.
96 Montero LS Daily driver.
88 Audi 90 Quattro marking it's territory.
69 Bronco built but uncut garage queen.
TANSTAAFL
Re: Replace Rod Bearings [Re: sewerrat] #1013108 11/17/10 03:33 AM
mxmikie Offline
yep align bore and resize along with a crank turn/polish there is never time/munny to do it right the first time....... but funny how you can find time and munny to do it over <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: Replace Rod Bearings [Re: mxmikie] #1013109 11/17/10 04:28 AM
Thanks, yea I know to check the crank. I have other projects going on now and really don't have the time, money or interest to rebuild or buy a new engine for this rig.
A buddy has a lift in his shop so I'll try to bring it over there and take a look.
How can I tell if the crank is OK? How much scoring is too much?
Re: Replace Rod Bearings [Re: 89montero] #1013110 11/18/10 05:49 PM
W
willwinchforfood Offline
if there is any scoring its to much. you also have to measure the shaft lobes to make sure they arent worn down to much and are still actually round. there are a ton of measurements you can find in the factory manual. and dont use cheap stuff to measure with. the tolerances are small, you need good tools.
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
Re: Replace Rod Bearings [Re: willwinchforfood] #1013111 11/18/10 10:51 PM
Rake a penny across the journal. If it leaves a mark, the crank has to be turned/polished.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6430 MB (Peak: 0.7667 MB) Data Comp: Off Server Time: 2026-05-29 14:43:40 UTC
