Pajero 4M40 (2800) Parts Cross-Reference List!
#1013318
11/19/10 11:34 PM
Oil Filter WIX 51067 and 51809 not yet verified. crossed from Baldwin bd28 and bd7095 from previous post.
Part Number: 51809 UPC Number: 765809518094 Principal Application: Thermo-King Refrigeration Units (Full-Flow/By-Pass) All Applications Style: Spin-On Lube Filter Service: Lube Type: Full Flow/By-Pass Media: Paper Height: 6.991 Outer Diameter Top: 3.689 Outer Diameter Bottom: Closed Thread Size: 26X1.5 MM By-Pass Valve Setting-PSI: None Anti-Drain Back Valve: Yes Burst Pressure-PSI: 250 Nominal Micron Rating: 6
Part Number: 51067 UPC Number: 765809510678 Principal Application: Ford Ranger, Bronco II w/Mitsubishi Diesel (85-87), Mitsubishi Fuso Trucks All Applications Style: Spin-On Lube Filter Service: Lube Type: Full Flow/By-Pass Media: Paper Height: 5.362 Outer Diameter Top: 4.016 Outer Diameter Bottom: Closed Thread Size: 26X1.5 MM By-Pass Valve Setting-PSI: 19-22 Anti-Drain Back Valve: Yes Burst Pressure-PSI: 270 Max Flow Rate: 11-13 GPM Nominal Micron Rating: 30
Gasket Diameters Number O.D. I.D. Thk. Attached 2.874 2.600 0.125
Gasket Diameters Number O.D. I.D. Thk. Attached 2.775 2.470 0.255
PHP: 7.4.33 Page Time: 0.007s Queries: 14 (0.005s) Memory: 0.5830 MB (Peak: 0.6230 MB) Data Comp: Off Server Time: 2026-06-17 10:48:50 UTCValid HTML 5 and Valid CSS
