For you Gen3 owners that never knew! #1013762 11/26/10 03:34 PM
dougl3nc Offline OP
Here you go! NHTSA: 01V254001
____________________________________________________________
Auto Recall Date: 08/03/2001
Vehicle Component: SERVICE BRAKES, HYDRAULIC:POWER ASSIST:VACUUM
Estimated Vehicles Affected: 39020
2001 MITSUBISHI MONTERO Defect Summary:
VEHICLE DESCRIPTION: SPORT UTILITY VEHICLES. THE ACCUMULATOR THAT IS INSTALLED ON THE HYDRAULIC BRAKE BOOSTER MAY HAVE BEEN IMPROPERLY MANUFACTURED. OVER A PERIOD OF TIME, THIS COULD RESULT IN LEAKAGE OF THE PRESSURIZED NITROGEN GAS FROM INSIDE THE ACCUMULATOR.
Defect Consequence:
THE LOSS OF THIS GAS PRESSURE COULD RESULT IN AN ABNORMAL NOISE FROM THE LEFT SIDE OF THE DASH PANEL WHEN THE BRAKES ARE APPLIED, AND POSSIBLY A DELAYED FIRST TIME BRAKE BOOST ASSIST AFTER THE VEHICLE HAS BEEN PARKED FOR A PERIOD OF TIME, WHICH COULD RESULT IN A VEHICLE CRASH.
Remedy:
DEALERS WILL INSTALL AN IMPROVED ACCUMULATOR. OWNER NOTIFICATION MAILING BEGAN OCTOBER 1, 2001. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT MITSUBISHI AT 1-800-222-0037.
1989 Raider SWB Auto 3.0L...It's ALIVE!
Currently on a shakedown cruise...
Re: For you Gen3 owners that never knew! [Re: dougl3nc] #1013763 11/28/10 07:05 PM
brubren3815 Offline
Already had mine done. It started making a "chirp" noise. It took them all of about an hour to fix it. They replace the little black sphere that sits on top of the ABS..
2002 XLS /LSD/Thule Rack /PIAA Extreme White headlamps /K+N system/Michelin LTX MS--KYB gas-adjust all around
95 LS-- Dual Bouncy Seats 234k and still rockin'
Re: For you Gen3 owners that never knew! [Re: brubren3815] #1013764 11/28/10 11:02 PM
dougl3nc Offline OP
Me too, but there are a few on here that paid out of pocket to have it done and deserve their money back. Also posted for a new member that was having problems and was told to go buy that part and replace it.
Re: For you Gen3 owners that never knew! [Re: dougl3nc] #1013765 05/20/12 08:18 PM
monty90 Offline
Hello, I know this ia really old post but I can?t find any more info.
My brother?s montero was fixed by the dealer for this issue, but the same day the issue return now the dealer said they need to replace the whole part more of a $1,000 just in parts it? s what they couted. Could it be that the brake booster accumulator that the dealer install it?s defective???
Any comment would be very helpful
Pd. my SAS Gen I it? s waiting for the 3.5 swap after my 3.0 with more than 250,000 miles it?s toast
Mitsubishi Montero 1990 LWB, Rear Air locker, SAS D44, superwinch hubs, bouncy seat, moonroof, custom brushguard, custom rack, GPS Meridian Magellan, dual Red Optima Red, Bilstein 7100 shocks, Hellas, 35x12.50 R15 Muds, 10,000 winch
Re: For you Gen3 owners that never knew! [Re: monty90] #1013766 05/20/12 09:00 PM
METALMOVER Offline
Id call Mitsubishi, is it the exact same issue? Did it remedy it for a short time? When you call Mitsubishi DO NOT bad mouth the dealer, the dealer will get a notice your calling, in fact you might want to talk to the service manager first at the dealership and ask him what he would do. I have seen the manufacturer give you either a goodwill part or at least a partial goodwill. I do know ABS actuators I believe they are called, are expensive. Good luck. METALMOVER <img src="/forums/images/graemlins/cheers.gif" alt="" />
1987 Raider,2.6,mt,78"Meyer snow plow,100lb. Doberman alarm,weber carb, lockouts from here- 1989 V-6,SWB, A.T. 4x4, 31'S
Re: For you Gen3 owners that never knew! [Re: METALMOVER] #1013767 05/22/12 05:36 AM
monty90 Offline
Yes it's the same issue, I talked to the sevice shop manager it's seems that the M-ASTC-ECU is not working at all, tomorrow they're going to check for voltage, hopefully it all ends there, since I have two GEN III in junkyards, I think it's not going to be more than a hundred bucks, let's see
Thanks
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6131 MB (Peak: 0.7005 MB) Data Comp: Off Server Time: 2026-06-21 12:20:10 UTC
